Question about GE Spacemaker JVM1640SJ Microwave Oven
Model JVM1340WW 002 won't turn off. tried unplugging overnight to reset, but it still runs when I close the door,
  • GE Master
  • 9,098 Answers
Is it cooking or not when you simply close the door? In other words, does a cup of water get warm after a few seconds?
If it is NOT cooking when you just close the door, and some combination of fan, light, and turntable are what's running, then you probably just have a defective door switch or door switch mount and should see these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
model  JVM1340WW 002
If it IS cooking just when when you shut the door, then you probably have a shorted cook relay on the control circuit board, and we can repair that for you for $39.95 postpaid.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jan 02, 2011
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Frigidaire microwave won t turn off
this is a problem with your programme timer these can be expensive to replace and because of the age you will probably be better buying a complete new unit as you could repair it and you could come across other related problems and could end up spending a fortune sorry i couldnt be any more help
Nov 08, 2007 | Microwave Ovens
Ge spacemaker xl jvm1340WW error message e2
please make this step , use the multimeter, and fix it. Merry Christmas.
F2 Oven cavity thermistor closed Check oven thermistor for continuity. Replace if zero or infinite ohms.
Dec 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is on when you shut the door
I tried all the things on your website. Holding the clear button , unplugging,...
So I went back to the last operation that I was doing when the problem started.
I was using "reheat" so I put a glass of water in the micro turned on reheat 1 serving.
It started and then I hit clear after a few minutes and the problem went away.
Dec 15, 2008 | GE Advantium 120 Convection/Microwave Oven
Not working model # jvm1339bw 002
Check the main internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Jan 30, 2008 | GE JVM1340AW/BW/WW Microwave Oven
GE JVM1340WW
One of the door switches may be sticking due to grease or carbon buildup. Or you may have a loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
159 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
