Question about LeapFrog Leapster Explorer Learning Game: Disney Pixar Toy Story 3
How to upload leapster explorer video thats in dvd (vob format)
Have movies on my harddrive but whn I try to burn them they wont play in the DVD player
- It might be that your DVD does not have a compatible video codec
- you actually invest on video codec which converts any video file to .VOB
- There is a software that converts any video file format (example *.avi, *.mp4, *.mpg ) to .VOB
- This should be taken as personal use because we do have laws againts anti piracy (sorry, just a friendly advice)
May 16, 2011 | Office Equipment & Supplies
Tip
VOB movies for Acer Iconia Tab A500-Stream DVD VOB to H.264 MP4 to Acer Iconia...
Transfer/Play DVD VOB files to H.264 MP4 for Acer A500 <br />Join multiple DVD vob files into one for Playback on Acer Iconia Tab A500 <br /><br /><b>A VOB file (Video Object)</b> is a container format in DVD-Video media. VOB can contain video, audio, subtitle and menu contents multiplexed together into a stream form. VOB file can contain H.262/MPEG-2 Part 2 or MPEG-1 Part 2 video, MPEG-1 Audio Layer II or MPEG-2 Audio Layer II audio, but usage of these compression formats in a VOB file has some restrictions in comparison to the MPEG program stream. <br /><br />How to convert and play DVD VOB files on Acer Iconia Tab A500? For Acer Iconia Tab A500 can not accept this format. <br />Acer Iconia Tab A500 is also a great media player which supports a lot of media formats including files with XviD, MP4, H.264, H.263 as video format and MP3, WAV, WMA, eAAC+ as audio format. So you need to convert the files before transferring and playing them on Acer Iconia Tab A500. <br /><br />Aunsoft Video Converter is the best <b><a href="http://www.aunsoft.com/video-converter/">VOB to Acer A500 Tab converter</a></b> for you to transfer files to tablet. It makes it easy to transfer VRO files to Android tablet by converting DVD VOB to MP4 for Acer Iconia Tab A500. You may also deinterlace VOB to progressive mode for perfect playback on Acer Iconia Tab A500. <br /><br />Below is the quick step-by-step guide for you to <b><a href="http://canon-videoconverter.com/2011/06/join-multiple-dvd-vob-files-into-one-for-playback-on-acer-iconia-tab-a500/">transfer and play VOB to Acer Iconia Tab A500</a></b> via Windows XP, Windows Vista, Windows 7. <br /><br />Step 1. Load VOB to Aunsoft Video Converter. <br />Run Aunsoft Video Converter as the best VOB to Acer Iconia Tab A500 converter, and click the "Add" button to import the .vob videos. <br /><img src="a500-vob-converter.jpg" /> <br /><br />Step 2: Choose the suitable Acer Iconia Tab A500 format. <br />As we know, Acer Iconia Tab A500 supported video like XviD, MP4, H.264, H.263 format like MP4. Here just take H.264 HD Video (*mp4) for example. Choose Common Video &gt; H.264 Video (*.mp4) as output format. <br /><br />Tips: Click "Settings" to set the Video/Audio Parameters like Size (resolution), bitrate, frame rate, etc to be more suitable for Acer Iconia Tab A500. For example: Set Size/Resolution to 1280*800 pixels. <br /><img src="set-a500-profile.jpg" /> <br /><br />Step 3: <b><a href="http://www.aunsoft.com/video-converter/">Convert/Rip DVD VOB to MP4 for A500</a></b>. <br />After all the above settings, you can click "Convert" to start <b>conversion VOB to MP4 for Acer A500</b>. Only a few munutes later, you can get the generated files by clicking "Open" icon. <br /><br />When the conversion is done, just connect Acer Iconia Tab A500 to Widnows PC via USB cable, and mount the converted videos to Acer Iconia Tab A500. <br /><br /><b>Tips:</b> If you want to <b>join multiple DVD vob files into a large files for smoothy playback on Acer Iconia Tab A500</b>, just check "Merge into one file" to make it.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Why cant i upload my diamond one touch capture card to youtube pleeese help
Youtube, by default supports major video formats like MPG, AVI, MOV, WMV etc. If you are trying to load the .VOB files it may not support.
Try converting your videos to Youtube acceptable formats (mpg, avi, mov or wmv) and try uploading again. Also remember the maximum playback length of your videos shall be 15mins only.
Mar 05, 2011 | Diamond Multimedia Diamond VC600 One Touch...
Can not play vod file on computer
I assume you mean VOB. I have not heard of a VOD file...
If you have gotten your hands on a VOB file somehow, chances are they have been copied/extracted from a DVD. VOB stands for DVD Video Object and is the core file of a DVD containing the actual movie data, an MPEG movie stream and the supported audio.
To play the VOB files, you need to have a DVD player that supports VOB format. However, if you have the Windows Media Player (version 12 or higher) or VLC Media Player, it is good enough to play the file. Note that you will see a prompt telling you that it is an unsupported format, don't worry about it and just play it anyways. It will play just fine.
If you want to obtain the VOB file from a DVD for some reason, just open the DVD in Windows Explorer instead of playing it through a media player. The VOB file would most likely be under the VIDEO_TS folder. Some other files that you will also see in the folder are IFO and BUP. The IFO files are the information files containing meta data about the DVD and instructions for the DVD player on how to handle the disc. The BUP file is simply a backup copy of IFO files.
If you want to convert VOB file to AVI or a similar format, aviNET is a great tool to do that
Dec 01, 2010 | HP Computers & Internet
My videos i make will not upload to any of my editors?
The file that ir creates when you capture the video is DVD file format if your going to check the video it is video_ts folder.
Please check in help application of your editor on how to import VOB files
Jul 20, 2010 | Pinnacle Dazzle DVD Recorder
How do u upload a vid to facebook from a dvd
Make sure the video is encoded in one of the following formats:
QuickTime Movie (mov)
Windows Media Video (wmv)
AVI Video (avi)
MPEG Video (mpg, mpeg)
Windows Media Video (asf)
MPEG-4 Video (mp4, mpeg4)
Mobile Video (3gpp, 3gp, 3g2)
Matroska Format (mkv)
Flash Player Video (flv)
DVD Video (vob)
Ogg Format (ogm)
Nullsoft Video (nsv)
you need to add the Video application to your account. You can find this application here, you can click this link after you log in.
http://www.new.facebook.com/apps/applica…
Once you have this application, follow these steps to upload a video:
1-Go to your profile.
2-Select the Wall tab.
3-Click 'Video' inside the Publisher box.
4-Select which type of video you'd like to make.
5-Follow the on screen directions for your particular upload type.
When you're done, click "Post" to generate a story about your video and store the video permanently in My Videos
Hope I helped =)
Mar 31, 2010 | Facebook Social Network
How do I convert my video from the IFO or VOB format to a format I can edit and upload to facebook or youtube?
Hi...
U can download and install the software which converts ur video from ifo or vob to mpeg or avi in the below link...
http://www.allformp3.com/dvd-faqs/410.htm
Good Luck;-)
Jan 02, 2010 | Canon DC220 DVD Camcorder
What is the file format of the videos on the DVD-R discs? If they are .vod, concerned the program (Corel Videostudio) does not support input of .vod files. Can they be converted? Is there another way to...
Hey! As far as I know, vob is the format of videos on the DVD-R discs.
I think you need a conversion tool and this DVD Converter Ultimate will be of help to you. This DVD Converter can help you convert various video format (including vob format )to any video format, rip dvds to video and burn video to dvds for playing on DVD players. You can have a free try of it. Hope that helps.
Oct 28, 2009 | Hitachi DZ-MV550 DVD Camcorder
Editing a film
VOB format is MPEG-2 system stream and Media Player will play it. It may be required Codecs.
Sony DVD Cameras write data in vob format.
I would suggest to download Cole2K media Codec Pack in your PC, its free.
Nov 08, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
LeapFrog Leapster Explorer Learning Game: Disney Pixar Toy Story 3 Logo
442 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
Dustin
Dustin
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
