Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker (JVM1631). The door latching mechanism has failed and will not stay closed causing the the microwave to not function. Do you have any troubleshooting suggestions?
  • 2,382 Answers
Hi, normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order GE parts is Tritronics.
Posted on Jan 02, 2011
Fix my ge spacemaker microwave door from wiggling at the door hinges (not the latches)?
http://youtu.be/nIdT4kS3noY This link will show you how to gain access to the problem. Sounds like a lose screw or two
Jan 03, 2015 | GE Microwave Ovens
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacesaver Microwave oven is not warming anything up. All other functions are working normally.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
WARNING :
good luck
Apr 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I purchased a GE Spacemaker Microwave. I just
First check you owners manual for installation instructions if any. There may still be shipping materials in the unit that have not been removed. If you do not see any shipping materials then by all means call the service number. Your door latch may have been broken in the shipment orocess. It would be a valid warranty repair.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
121 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
