Question about Dishwashers
My dishwasher is a Smeg model STA 6143, and the door won't close. It seems fine until the last few centimeters, then it jams and won't close easily. If you press hard, it'll shut but not latch. Nothing appears to be stuck anywhere. We've tried jiggling the door but it seems somehow to be misaligned, although there's no reason why it should all of a sudden appear to be so. The electronics work fine, the racks fit fine (we also removed them, and the door still won't close), and nothing appears to be wrong, except this.
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
  • 1073 Answers
SOURCE: door won't latch
replace the door latch part number 8193830 it will fixya
Posted on Apr 22, 2008
Has anyone had any luck figuring this one out?
Posted on Aug 15, 2008
  • 7 Answers
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
I have had the same problem since our KitchenAid was new. The only solution so far is to try bending the metal door latch down slightly. You will know when you have bent it too far as the door will no longer close. Just bend it back up slightly. I used to work in the appliance industry and got the service man to admit that the door latch has been an issue and there is no real fix. I have looked at the new KA dishwashers and they have since redesigned the door latch. I am going to see if the new latch can be retrofitted into my Kuds01FLSS6 dishwasher. I will post on here if indeed it works.
Good luck
Posted on Jan 14, 2009
  • 27 Answers
SOURCE: Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Posted on Mar 19, 2009
My smeg di 612ca dishwasher door will not shut.any ideas?
Check that nothing is protruding from inside of machine. If still won't shut check that nothing is stuck in the closing mechanism. As a last resort contact manufacturer or service agent.
Aug 11, 2014 | Smeg Dishwashers
There is a screen filter at the bottom of most dish washers, if the screen gets dirty it probly won't drain properly. Check the screen and clean if neccesary. If not that, then pump may be getting weak.
Jun 25, 2012 | Smeg Dishwashers
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
Cleaning my Smeg PL50 dishwasher.
As long as the product is intended for use on cleaning domestic machines then there should be no issues with using it. Follow the instructions on the product and all will be ok
Jan 01, 2018 | Smeg PLA8743XU Full Console Dishwasher...
Smeg Microwave SA-971C2
the door protection circuit needs attention, the door catches operate microswitches, but there is also a third which is a crowbar microswitch. if all three do not operate in the correct sequence then the safety switch or fuse will go.
Feb 18, 2009 | Smeg FMC24 850 Watts Convection /...
Smeg Slimline Integrated Dishwasher
Hello Jan
The manual in the link suggests your dishwasher is in Cold Pre-wash mode. Wavy line and two plates. It may be stuck on it, or prehaps your particular model has a setting to pre-wash until programmed to do otherwise.
First tip is always to disconnect from the mains for 20 minutes and start again.
Due to the age of your machine, it may be in warranty, as some have 1 year and some have 5 year. You could also contact them direct and ask their service department.
Mar 01, 2017 | Smeg Dishwashers
Whirlpool ADG993, door fault: Hi, a few weeks ago soemthing broke on the door to my diswasher and it falls open wide with no stopping half way as usual. That was fine as the machine could still work,...
Laura, we are sorry to hear that you are experiencing a problem with your Dishwasher. Please send your name, phone number, address, full model/serial numbers and the date on which you purchased the Dishwasher to so we can further look into this for you.
Apr 17, 2017 | Whirlpool Dishwashers
Dishwasher Whirpool not finishing a cycle.
control board issue needs to be looked at by whirlpool tech in your area, still under warranty
Apr 10, 2008 | Smeg PLA8743XU Full Console Dishwasher...
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
