How do I get the top panel off of a kenmore 22802 washer. Most of these I expect to just pop open. it almost looks like you have to remove screws buried under the top
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Then see the following for a description of how to release the console and pull the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
Posted on Jan 01, 2011
How to replace lid switch on frigidaire top load washer
I believe same as Kenmore you have to remove the top panel, first remove the 2 plastic pc.s from the side panel, then u will see on each side a screw that needs to be removed, then lift panel up and out of way, u will see 2 gold clips near the center that need to be preyed or popped out, then the whole cabinet will come forward and out. look under it and u should see the door switch and a couple screws holding it to lid panel remove them as well, then unscrew the ground screw to the harness usually a green wire connected to the frame.
Feb 25, 2014 | Frigidaire CWS3600AS Top Load Washer
How do I get the top up on a kenmore washer. I need to replace the lid micro switch.
Their are 2 different ways to remove the top based on when that washer was made the manufacture used differnt methods this is how to do it on each style
remove diagonal panel between washer and control panel
in the back of washer top will either be 2 brass colored clips
or in the very back egde of top will be 2 5/16th inch hexhead screws
for clips place a small screwdriver in front of that clip and pop clips off and slide top forward
for the screws remove screws from behind top in the left/right corner..pull top forward a bit and lift up a little the plug for the lid switch will be in front right side..squeeze the release for that plug,unplug swicth plug then remove top
in both cases lid switch asm. will be on right side of top on the underpart of it
Gene
Aug 24, 2011 | Kenmore 80754 Top Load Stacked Washer /...
The switch # 3949238 on my kenmore washer #110.29842991 is broken. how do I remove the top cabinet so I can replace the part?b
Disconnect the power first.
Many washers have spring clips holding the lid in place, and a putty knife or scraper can be shimmied in to compress the clips and open the lid for service.
Some units, esp old Maytags, have 2 screws near the bottom of the front panel, and removing them will let the front panel tilt out, granting access to the top cover from the front.
Some later Whirlpool and Kenmore units have a cabinet that comes off in one piece. You'll need to remove 2 screws holding the splash panel to the top of the washer. Flip the panel up giving access to the timer/switches area. Disconnect the white plastic wire connector, then use a screwdriver to pop the metal clips in the corner. Set these aside, and the whole cabinet will tilt forward, and can then be lifted off the washer base/back. Space to work will be an advantage, for this type of cabinet.
May 18, 2011 | Kenmore Washing Machines
How do I remove the back of the machine on a Model #11026892690 Kenmore 80 Series Washing Machine to change the belt?
don't touch the back,there isn't a belt in kenmore washers and don't touch the back panel,there are white covers on each side of the top panel,pop them off and remove the two phillips screws,one on each side,then flip the panel up,with a screw driver pop the two metal clips,just stick the screw driver in the hole and on top of the clip and push back to the wall and the clip will repease,now in the middle of the clips you'll see the lid switch connector,separate it,open the lid and grab the frame,tilt it up and back at you and remove the frame,on the bottom you'll see the pump,remove the two clips and pull off the pump,then remove the two screws and pop the two clips and slide out the motor,on the back of the motor you'll see the coupling,that's what broke,you need to replace the motor coupling
Oct 30, 2010 | Kenmore Washing Machines
Working on a Kenmore 80 series (11020872990) washing machine, do you remove the rear panel or the front/sides panel?
no don't touch the back at all.unplug it,then pop off the white end caps on the console and remove the two phillips screws,lift up the console,unplug the lid switch connection in the top middle and with a screw driver pop off the metal clips,just stick the screw driver in the hole and on top of the clip and just push towards the back wall and it will pop out,then open the lid and tilt the frame forwards and back at you and remove the hole outside frame.what problem are you having?let me know how you make out
Oct 16, 2010 | Kenmore 22642 Top Load Washer
How do I open the top lid to get to the lid switch on a Kenmore 70 series washing machine?
Remove the screw on both sides of the control panel . Pull the panel foreward and tilt back . Unplug the plug coming out of the cabinet and using a flat head screwdriver , pop the clip on both sides thru the slots closest to the front of the cabinet . Tilt the whole cabinet foreward . Do not try taking the lid off the washer .
Aug 03, 2010 | Kenmore 24032\24036 Top Load Washer
My washer appears to have a short in the control panel. Stops during some cycles, and doesnt work on the cold water choice. However, if i press hard on the panel, the cold will begin to fill the drum. I...
Depending on your exact model number, see the following for access to the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=3db56c5149b02526181f69c9dbd2e80e
Nov 08, 2009 | Kenmore 23822 Top Load Washer
How do I access drain pump
take out two screws on top control panel,either in the back or in front or you might have to pop off covers on left and right side of panel and then you'll see screws,the panel is on hindges,lift it up,now you'll see two metal clips put screw driver in the front part of clip and push screw driver back towards panel and clip will release,remove lid switch wire clip and pull the frame to you and move it out of your way,look down under the front of tub and remove the two metal clips holding pump on
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Jan 23, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer
nope, the knob does not come off in order to remove the panel off.
look at the edges of the back of the control panel, you should find philips screws at the back. if not then figure out how to remove the plastic edges of the panel. they are covering the screws.
if you found the screws, remove them then pull the panel towards you and the plastics hooks at the bottom of the panel would slide out towards you.
then you were able to open the control panel..
hope it works..
tnx 4 using fixya,
drcool
Sep 10, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
