Question about Kenmore Elite 45986 Front Load Washer
Fault code int. for a 110.4770 I get a INT or lnt or int were the door lock is flashing and the power button is lite blue but will not power off the washer if you push it, no other buttons work.
  • 107 Answers
SOURCE: Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Posted on Mar 13, 2009
SOURCE: machine won't go into the spin / drain cycle
depends on the make of the machine...look at lid switch....
Posted on May 21, 2009
SOURCE: Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
Posted on Jun 04, 2009
mgprice
  • 744 Answers
SOURCE: He5t Kenmore ELITE front load washer flashing f35 code
Hi, Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. If you have any further questions or concerns please feel free to comment again, Good luck.
Posted on Jul 07, 2009
  • 4 Answers
SOURCE: kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Posted on May 03, 2010
Source code for implementation of linked list using opengl in vc++
Source code:
#include
using namespace std;
class linklist
private:
struct node
int data;
node *link;
}*p;
public:
linklist();
void append( int num );
void add_as_first( int num );
void addafter( int c, int num );
void del( int num );
void display();
int count();
~linklist();
linklist::linklist()
p=NULL;
void linklist::append(int num)
node *q,*t;
if( p == NULL )
p = new node;
p->data = num;
p->link = NULL;
else
q = p;
while( q->link != NULL )
q = q->link;
t = new node;
t->data = num;
t->link = NULL;
q->link = t;
void linklist::add_as_first(int num)
node *q;
q = new node;
q->data = num;
q->link = p;
p = q;
void linklist::addafter( int c, int num)
node *q,*t;
int i;
for(i=0,q=p;i {
q = q->link;
if( q == NULL )
cout return;
t = new node;
t->data = num;
t->link = q->link;
q->link = t;
void linklist::del( int num )
node *q,*r;
q = p;
if( q->data == num )
p = q->link;
delete q;
return;
r = q;
while( q!=NULL )
r->link = q->link;
delete q;
return;
r = q;
q = q->link;
cout}
void linklist::display()
node *q;
cout for( q = p ; q != NULL ; q = q->link )
coutdata;
int linklist::count()
node *q;
int c=0;
for( q=p ; q != NULL ; q = q->link )
c++;
return c;
linklist::~linklist()
node *q;
if( p == NULL )
return;
while( p != NULL )
q = p->link;
delete p;
p = q;
int main()
linklist ll;
cout ll.append(12);
ll.append(13);
ll.append(23);
ll.append(43);
ll.append(44);
ll.append(50);
ll.add_as_first(2);
ll.add_as_first(1);
ll.addafter(3,333);
ll.addafter(6,666);
ll.display();
cout ll.del(333);
ll.del(12);
ll.del(98);
cout return 0;
May 19, 2011 | Computers & Internet
Actually i want a source code for tower of hanoii problem which can be compiled and run in microsoft visual c++ 6.0....pls help
I am sending only the half code, rest you have to complete:-
#include <stdio.h>
#include<math.h>
# define MAXSIZE 40
using namespace;
//int stack[MAXSIZE];
//int top;
class TowerOfHanoi
public:
int stack[MAXSIZE];
int top;
TowerOfHanoi(int n)
{ int i;
top=-1;
for(i=n;i>0;i--)
push(i);
TowerOfHanoi(){
top=-1;
void push(int y)
{if(top>MAXSIZE){
printf("\n STACK FULL\n");
Apr 26, 2011 | Computers & Internet
I have problem in how to call the matrix using fuction
I don think u are in the right way to program the Matrix in C language, i found a lot of syntax error in your code, but nevermind i had correct it for u. Maybe still need a little correction for your own. Following code:
void matrix(int a[2][2],int b[2][2],int c[2][2]);
main()
int a[2][2]={{3,3},{4,4}};
int b[2][2]={{1,1},{2,2}};
int c[2][2]={0},i,j;
matrix(a,b,c);
printf("product of 2 matrix is");
for(i=0;i<2;i++)
for(j=0;j<2;j++)
printf(" %d",c[i][j]);
printf(" ");
int row,col,sum1=0,sum2=0;
for(col=0;col<2;col++)
row=0;
sum1=(a[row][col]*b[row][col])+(a[row][col]*b[row+1][col]);
c[row][col]=sum1;
sum2=(a[row+1][col]*b[row][col])+(a[row+1][col]*b[row+1][col]);
c[row+1][col]=sum2;
Sep 10, 2009 | Intel Computers & Internet
L 6 CODE ON SHARP ARM205 HOW DO I REPAIR PLEASE
L6 is a Polygon Motor Lock.
Unfortuantly there isn't a whole lot you can do. You can try and reset the code, but most likely you will need a Certified Sharp Rep to replace your LSU.
To reset,
Make sure your machine is awake and ready to copy.
Simply press,
c, *int*, 0, *int*
(Clear, interrupt, zero, interupt)
The machines screen will flash blank.
Simply type in
'14'
and press copy.
The machine will reset the code and restart.
If this does not work enter sp modes again.
and try code '16'
Ta!
Willi Williams
Service Engineer.
Aug 17, 2009 | Sharp Office Equipment & Supplies
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Jul 03, 2009 | Microsoft Computers & Internet
Center locking not working electric window not working
I had the same problem with my 2002 2.5 tdi, i spent weeks looking for the fault an found it to be 2 broken wires inside the drivers door rubber wiring loom ( near door hindges ). it was causing same fault no int/light - no central locking to drivers door - no electric windows.
i managed to repair wires and it now fine..
Mar 20, 2009 | 2001 Audi A4
Java source code
* To change this template, choose Tools | Templates
* and open the template in the editor.
//package optimalcluster;
* @author CSEEXAM2008
import java.awt.*;
import java.awt.geom.*;
import javax.swing.*;
public class GraphingData extends JPanel {
double[] data = {
0.504782921308152, 1.174144134378306, 2.0933754535558546,6.2625807939548823,8.8484441414277364,10.0000003,12.908978000,14.8906789456,12.9087654567 };
final int PAD = 20;
@Override
protected void paintComponent(Graphics g) {
super.paintComponent(g);
Graphics2D g2 = (Graphics2D)g;
g2.setRenderingHint(RenderingHints.KEY_ANTIALIASING,RenderingHints.VALUE_ANTIALIAS_ON);
int w = getWidth();
int h = getHeight();
// Draw ordinate.
g2.draw(new Line2D.Double(PAD, PAD, PAD, h-PAD));
// Draw abcissa.
g2.draw(new Line2D.Double(PAD, h-PAD, w-PAD, h-PAD));
double xInc = (double)(w - 2*PAD)/(data.length-1);
double scale = (double)(h - 2*PAD)/getMax();
// Mark data points.
g2.setPaint(Color.red);
for(int i = 0; i < data.length; i++) {
double x = PAD + i*xInc;
double y = h - PAD - scale*data[i];
g2.fill(new Ellipse2D.Double(x-2, y-2, 4, 4));
g2.setPaint(Color.black);
g2.fill(new Ellipse2D.Double(x-2+4, y-2+4, 4, 4));
g2.setPaint(Color.blue);
g2.fill(new Ellipse2D.Double(x-2+6, y-2+6, 4, 4));
g2.setPaint(Color.pink);
g2.fill(new Ellipse2D.Double(x-2+8, y-2+8, 4, 4));
private double getMax() {
double max = -Integer.MAX_VALUE;
if(data[i] > max)
max = data[i];
return max;
public static void main(String[] args) {
JFrame f = new JFrame();
f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
f.add(new GraphingData());
f.setSize(400,400);
f.setLocation(200,200);
f.setVisible(true);
Feb 07, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
DOOR AJAR LIGHT (bad sensor?)
I'm pretty sure that they are integral to the door lock assembly on that model, would need to replace the whole door lock if that is the case. Best to get the Ford dealer to plug in their computer and check the signals from the door locks to see which one is at fault. Check central locking and power mirror fuses first, if no power to door locks then the door ajar sensors will have no power as well.
Oct 25, 2008 | 2003 Ford Explorer
In visual basic how will we change the backcolor of the form randomly when we click the command button?
Paste this code on you button. This generates a random color.
Red = Int(Rnd * 255)
Green = Int(Rnd * 255)
Blue = Int(Rnd * 255)
Form1.BackColor = RGB(Red, Green, Blue)
Oct 06, 2008 | Computers & Internet
900i 1992
hi 22491 is a unknown code is this correct
Aug 04, 2008 | 1992 Saab 900
Kenmore Elite 45986 Front Load Washer Logo
59 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
