Question about Nintendo Wii Console
Hooked up , its in black and white. do i have to have internet for it to work
Your problem is where the AV cables(Yellow, white and red) are plugged. Try around with the different place to plug them in, or look at your tv's manual. You don't need internet for the color to be normal.
Posted on Jan 01, 2011
T-103 Black, white and ground what thermals go where
You should be able to find a wiring here. Search you should have a white, red, black, wire there. hook the white to the neutral or common. then hook the black wire to term # 1 the red wire to term # 3 and then hook the load side to term 2 and 4. it should work doing this. don't forget to hook up the ground. hope this was helpful. contact me if u need more help
Feb 03, 2015 | Intermatic T103 Indoor 120-Volt 40-amp...
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
Hampton Bay Carlsbad 52 in. Brushed Nickel Ceiling Fan. I had an electrician install the unit with two different remots and transmitters (1 came with unit and different one) but none of the remotes operate...
either you have a problem with the transmitter or with the electrican this is an easy job not to much can go wroung.lrt me see if i remember hook black to black white to white and hook up ground. good luck
Aug 12, 2011 | Hunter Ceiling Fan Light Remote Control
Black, white, red, wires on motor and the connect
White is always neutral so I am going to say hook it to brown, unless you have another white wire.
Black on a motor is usually high speed, so hook it to black
Red is usually low speed to hook it to yellow. If you do not get
high speed then hook black to yellow and red to black
Jul 16, 2010 | Heating & Cooling
Where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Nov 15, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Nintendo Wii Console Logo
148 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
