Question about MSI K8T Neo-FSR Motherboard
Want to add a second hard drive and am wondering if there are jumpers on the motherboard that need to be set
    Sergeant:
  • 223 Answers
Usual all have tow provision set of IDE cable and more power cables , just use them to add your second Hard disk, if you are not more clear just see this tutorial , click here to view , but now a days all getting external hard drive to make it more easy to do this process. It will be available in all Hardware shops.
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 02, 2011
What jumper setting do I need to add a second 3.5 hard drive into my PC.
Most likely you can use the "cable select" or "CS" position in order to add a second drive. If that doesn't work, then use the "Slave" position.
Apr 04, 2011 | Maxtor Hard Drive
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Want to remove wd2500 drive from HDD enclosure and
OK your hard drive is an ATA drive.
You motherboard will have two hard disk controllers, on the 1st controller the ATA cable will have two connectors - a connector will have the C drive hard disk attached to it and the jumper on the hard drive will be set as the Master drive. You may also have a CD or DVD drive connected to this cable, if so then the CD or DVD drive will be jumpered as a Slave drive.
If the second connector does not have a drive connected, then you can connect the second hard drive to this connector BUT it needs to be jumpered as a Slave drive.
You may elect to connect the second hard drive to the second IDE controller instead on the first controller. If there aren't any drives on the second ATA cable then the second hard drive can be jumpered as either a Master or Slave drive.
If there is a drive on the second ATA cable you need to determine the jumper setting of that drive and then set the jumper on the second hard drive to a different setting. BOTH drives on the same cable CANNOT have the same drive setting.
After installing the second hard drive, check the BIOS configuration of the second hard drive, if the hard drive is detected then when Windows boots up you will see the hard drive and its contents.
Dec 08, 2009 | Western Digital Caviar WD2500BB 250 GB...
Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
I have a m2n61-ax dell board,I install a second dvd rewrite lg window will not see the drive????
if These Are IDE devices, ensure That The Jumpers Are Set To Slave And Master. If The Device still Is Not Recognised, Try Putting It On The Secondary IDE Channel, with A seperate Cable. Or Add it to The Hard-Drived Cable. If The Hard-Disk Is Jumper-Set as Slave, Move Jumper-Pin ( Small Plastic Block ) on the rear Of The Drive To Master.
Mike @ Compurepair.
Oct 16, 2009 | Dell Computers & Internet
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Apr 04, 2009 | Dell Dimension PC Desktop
Power up problems
To enter setup (Refering to the bios/cmos), press the Delete key very two seconds untill the bios main menu loads. You need to go to the menu heading - Boot.
If you added another hard drive to you're system the IDE (hard drive) it's jumper settings may not be correctly set. If there are now two IDE drives both the primary master & secondary drive's jumpers must be set correctly. You will ned to look at the white sticker on the drive for the correct jumper settings. Many primary IDE drives pin jumper is set as a single master drive with out a secondayr drive attached in the system. When you add a second drive the pin jumper one the master drive will most likely need to be changed to master with a slave. The second drive will also need it's jumper set as a slave drive. Once this has been adjusted you need to enter the bios & make sure you're primary master drive is set in the boot order. Most PC's boot order is as follows.
1st Boot device, floppy drive. (If one is connected to the system).
2nd boot device, CD-ROM drive.
3rd boot device, master IDE drive.
Please use the help of you're manual to guide you for these settings.
AOpen MX46L web site. http://download.aopen.com.tw/Default.aspx
You must set the three drop down menu's to get you're board's drivers & manual. In the first menu choose motherboard, in the second menu choose MX46L & in the last menu choose manual. For drivers, the third menu choose drivers.
Still heave more questions? Just ask.
Mike
May 18, 2008 | AOpen MX46L Motherboard
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
MSI K8T Neo-FSR Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
