Question about LG 24 in. LDS 5811 Built-in Dishwasher
What size wrench or socket will fit on top of front feet? 14mm to big & 13 to small.
3 Suggested Answers
onyxvu
  • 74 Answers
SOURCE: Ring tone file size
i have found about 15- 17 seconds is as long as it can be. less than 290kb. you need a music editing program. also making it mono instead of stereo helps to squeeze that extra second in there.
Posted on Apr 15, 2009
  • 884 Answers
SOURCE: My top loader lg washer is unbalanced with every
Is there a weight under the base that has come loose or broken off? It stabilises the drum because of it's mass
Posted on May 17, 2012
What size socket do I need to remove the brake calipher on a 1999 Ford Escort? My socket 9/16 is a bit to big and I almost stripped the bolt, and the other sockets in my set are too big or small
Since 1980 you need a complete set of metric wrenches &
sockets, to work on any vehicle
You need a 14 mm, if you do the math, based on what
you said
.0395 is one milimeter
Apr 03, 2013 | Cars & Trucks
Tools for oil change
You only need a few. You need a wrench or socket that fits the oil pan drain plug. Car makers have used all sizes of drain plugs, don't know Saturn's, anywhere from 13 millimeter to 19 millimeter size wrench or socket. One of them will fit yours.
So one wrench (when you find the right one) and you will need a drain pan to catch the oil. Next you will need an oil filter wrench or tool. There are several types and sizes-when you buy the new oil filter you can get the filter remover that fits your filter . A parts person should be able to help you select the right one. Also buy a small funnel to pour new oil into the engine .And don't forget to have a few rags handy to clean up spills and wipe off areas. That's about all that is normally required.
Dec 21, 2012 | 2004 Saturn ION
WHAT SIZE SPARK PLUG SOCKET TO USE
Depends on which size plug you are using. Hint, keep changing sockets until you find the one that fits. They are not metric.
There are three sizes of plug in normal use, 10mm, 14mm and 18mm. (They are identified by their thread size) The socket sizes for these are 5/8" (16mm) 13/16" (21mm) and 15/16" (24mm). However, many 14mm plugs (the most common size) have 5/8 hexagons, and many 18mm plugs have 13/16 hexagons!
May 20, 2012 | Garden
Removing blades from a john deere eztrak z425
I have the same problem. 3/4 in. too big, 11/32 too small, 19mm too big, 17 mm too small. I don't have a 18mm or 21/64 in any of my wrench sets because they are not common sizes. I guess I'll have to contact JD.
Apr 22, 2012 | Garden
Just need to know the bolt head size for caliper hold down bracket for 07 dodge caliber rear brakes
im seeing 13 mm to be the size for those bolts but i would bring a 14mm 15mm 17mm 19mm socket/wrench as well. goodluck
Mar 19, 2011 | Dodge Caliber Cars & Trucks
I need to know the size of the wrench (socket) in order to remove the oil drain plug
a cheap set of socket are your best bet as you will also get a socket wrench and extensions as well as a complete small sized set for future use
However it should be 1/2 inch
Feb 10, 2010 | 1997 Mazda Protege
What is the size of the allen wrench needed to fit the oil pan drain plug in a 1995 toyota celica
The oil pan drain plug should require a 14mm hex head wrench to remove. The transmission pan requires a 10mm allen head socket, or wrench to remove. Are you sure you're trying to remove the correct drain? The oil drain should be on the passenger side and on the rear corner of the pan.
Dec 12, 2009 | 1995 Toyota Celica
How do i replace an idler pulley on a 02 xg350l
the 02 and the 05 are identical. There are TWO idler pullys ... one for the power steering, and the other for the AC compressor & alternator -- WHICH ONE? In any event, you'lll need to remove the right front wheel and the splash guard (10mm bolts) to access either of the pullys. Use 14mm wrench (or ratchet & socket) to loosen the appropriate pully (Pwr Steering has 14mm nut & two 14mm bolts), The other pully has one 14mm nut & one 14mm bolt.
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Oct 14, 2009 | Hyundai Motor 2005 XG350
I need to replace the abs sensor on a 1995 Chevy
No way are they 14.5 mm. Try an SAE socket instead of metric. I think you will find that a 9/16 is the correct size.
Oct 05, 2009 | 1995 Chevrolet Cargo
Where is the fuel filter located on 93 sr5 v6 4wd ?
I did this last night and it took me about 3 hours. You will need some 12mm, 14mm, and 17mm wrenches and sockets, and a couple of long extensions for your socket. Disconnect your battery, remove the front passenger tire, and then disconnect your power cable on the starter (12mm nut). Remove the starter (one 14mm bolt on bottom, one 14mm nut on top). You'll probably have to use your extensions to get that top nut off. Then take the banjo nuts off the filter, let it drain a minute, and unbolt it from the engine. Put the new one in, tighten the banjo nuts with a torque wrench to 22lbs, and start reassembling everything. Assembly goes a lot faster than disassembly. Keep in mind that this thing is in the worst possible position, and there is no way for you to reach anything, fit your hand where it needs to go, and is a giant contortion act from beginning to end. I hope the sorry Japanese engineer that came up with this idiotic configuration reads this and commits seppeku, or at least gets some bad fugu
Aug 12, 2009 | 1993 Toyota 4Runner
LG 24 in. LDS 5811 Built-in Dishwasher Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
