I have a Kenmore HE3 washing machine. The door won't open after running a load this morning. I took off the front panel and have pulled down the door mechanism latch and the door still won't open. Do you have any other suggestions for a single mom who is trying to save $$ by fixing it herself? Currently, I have the washer unplugged and will leave it this way for about an hour to see if it resets itself. Any information is greatly appreciated!! Thank you so much in advance.
  • 1,998 Answers
So your pulling down on the cord while pulling out on the door in order to open the door also what is the model number of your machine and most likely it is a bad door switch assmebly which to get one the cheapest you would go to www.marcone.com and under contact us is there 1800 number this is the cheapest appliance part place that i know of and they are the largest and mail to your door as well as for the how to disassemble your machine i think i can help you with that part message me back your model number and i will send you back a schematic and how to instructions and very nicely done on taking off the lower panel and getting to the pull cord for the door dont see that too much If you have any further questions please message me back them as well and when our chat has concluded please remember to rank how this opinion has helped in your appliance situation Thanks again and Happy New Year
Rick
Posted on Jan 01, 2011
Kenmore washer HE3 broken door latch. How do you replace
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Dec 29, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elliet washing machine, front loader
To open the door manually:
UNPLUG the machine...
Remove the toekick panel (way down at the bottom).
Feeling along the inside of the front panel. You should be able to find a tab shaped like a teardrop attached to the door latch unit.
Pull the tab down just a little bit ... gently ... until the door opens (or you hear the latch click - then try to open the door).
Is the machine displaying a code?
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he3 washing machine door glass
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
HE3 Washer door will not open
chris unplug unit.take off bottem paneland reach up in door latch area.their is a tab you can pull to open locked door.is the washed draining.you may need to clean pump if not.God bless,tom
Dec 30, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 lock
Have you tried pushing the door lock/unlock button? I think it may be called the "rinse & spin", and under that it says door lock/unlock.
Sep 20, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
