Question about Lands Phones
I get a dial tone on the phone. Outgoing calls do not go through. Incoming calls do not ring on phone but go directly to my email. The answering machine on the phone is on but does not record the message.
  • Lands Phones Master
  • 6,771 Answers
It sounds to me you took a power surge on your system, unplug the phone from the wall receptacle, also remove the phone cord from the wall, let it sit for at least 30 minutes or more the longer the better. If there is no change, it is time to replace entire system.
Posted on Jan 01, 2011
Why can;t I hear anything on outgoing calls
Cordless/Corded Phones, Digital Photo Frames 1-888-331-3383 Mon-Fri 7:00AM-7:00PM CST
Contact our team for assistance.
Mark
Motorola Support
Sep 14, 2014 | Motorola IT6-2 DECT 6.0 2-Handset Digital...
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
Nokia N72 mobile phone, am unable to hear dial tone when dialling and unable to hear incoming call answering a call and unable to from them when I make outgoing calls.
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Jul 11, 2009 | Nokia Cell Phones
Phone goes straight to answer
Is there a "Do not disturb " button on? Or maybe a "Send All Calls". If there is, you will get a stutter dial tone when you go off hook.
Does this happen for both outgoing calls and incoming calls?
Jul 01, 2009 | Avaya 4610
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
