Question about Dualit CTS4E 4-Slice Toaster
Need a timer for mine. where can i buy one? - Dualit CTS4E 4-Slice Toaster
  • 61 Answers
Ebay but pricy
Posted on Jan 05, 2011
How do I reset the time?
Very common with this type of unit. The switches are prone to corrosion and failure. You can buy a new timer from Sears (~$150) or off Ebay (~$100), or use a simple, no tools procedure, I use on my Sears softener.
-Unplug the softener.
-Carefully remove the top cover from the softener (usually 2 tabs in front and 2 in back).
-remove the timer panel (mine is held on by 2 tabs, one on each side).
-unplug the wiring to the timer.
-remove the timer (mine is held in place by a little plastic hook at each corner, remove one side and first and then the other.
-with the timer out, you can see the switches. while pressing on one of the switches, move your finger in a circular pattern (this rubs the contacts together on the inside of the switch, allowing the contact material to "grind" through the corrosion). Do this with all the switches.
-to reinstall, reverse the processes.
Jan 05, 2016 | Kenmore Elite Hybrid Water Softener Gray...
I have the lightswitch timer. i have it programmed but it doesnt' go on unless i touch the switch. it shows auto and on before the correct time of 7pm. if i shut off, then auto on and a flashing off...
Most in-wall timer manuals suggest re-setting timer to restore functionality.
If re-set does not restore timer, then timer is probably bad.
To download Aube manuals:
http:///waterheatertimer.org/Aube-timers.html
There are 3 things to remember about timers.
1) Line noise and bad wiring can affect electronics inside timer.
Buy cheap circuit analyzer at home center and test nearby outlet that is on same circuit breaker.
2) Aube timers have internal rechargeable battery and cannot be exposed to temperatures below freezing
3) Industry standard is 1 year limited warranty on timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 21, 2011 | Aube Technologies Aube 7-Day Programmable...
The timer is not working. Can I buy the timer unit seperately? The transformer works fine when I wire it to bypass the timer.
Yes you can I was actually about to purchase one myself. I left mine on it's side for a couple of years and the mud built up on the inside.
http://www.aplussupply.com/intermatic/timermotors.htm
Mar 26, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
I have two vigoro water timers and the connection to the water faucet on both have broken. Can that part be bought or would it be cheaper to buy new?
Unfortunately, the housing is glued together.
I took mine apart with a hammer and screwdriver only to find that the entire input, valve and output assembly is one piece.
Even if you find a new threaded ring to install, it seems unlikely success could be obtained in terms of replacement.
Bummer - why is everything built to end up in a landfill?
A meal threaded faucet inlet piece would have avoided my need to discard this unit.
Jul 27, 2009 | Hardware & Accessories
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Don't know how to set-- need manual
I have one but no manual. Mine you just turn the dial in the middle clockwise to set the time. You put white stops on where you want the timer to turn on. Red where you want it turn off. Hope this helps.
Oct 16, 2008 | Intermatic 10A OUTDOOR TIMER
BOSH SHU 3030 Dishwasher timer
This weblink will help you
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Dualit CTS4E 4-Slice Toaster Logo
51 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
