Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
No headphone connect - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
    Sergeant:
  • 223 Answers
Hi gangster. you don't headset pin in your mothreboard , just get audio card in hardware shop and fit it to your motherboard and instal it , you have headset pin in audio card.( Audio card cost starting form 6$ )
Now usb audio drive also available in market just buy and plug it in USB port and plug your headset in that port.( Usb Audio card start from 3$)
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 02, 2011
How do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Apr 23, 2010 | Beyerdynamic DT 100 Professional...
How to connect headphones if tv doesn't have a jack
yes. go to radioshack and explain situation. They should have an adapter for it.
Apr 07, 2009 | Toshiba 50HDX82 50" Rear Projection...
Unable to connect headphones to Tv.
You TV have no headphone port.
You can download the user guide for your reference from:
https://docs.sony.com/release/KDF55WF655.pdf
Apr 24, 2017 | Sennheiser RS130 Headset
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
Headphones to tv have no sound
If you have connected your headphones directly to a headphone jack on your TV, it should work - check whether there is a separate headphone volume control.
If you have connected your headphones to the red/white "variable output" or "Line out" jacks on the back of your TV, these do not provide a headphone-level signal.
Please provide more detail on exactly how your headphones are connected to your TV, what make/model TV you have, and the connections between the two.
Apr 06, 2008 | Audio Players & Recorders
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Feb 20, 2008 | E-Machines eMachines Refurbished EMA...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
