Televison & Video Logo
Posted on Jan 01, 2011
I need to know the replacement code on Nexxtech remote 151826A for Magnasonic TV's remote 6142-09201
5 Related Answers
A
Anonymous
  • Posted on Jun 21, 2008
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
A
Anonymous
  • Posted on Oct 25, 2008
SOURCE: code
i need a remote code for 47" full HD to us with the sky remote
Anonymous
  • Posted on Oct 31, 2008
SOURCE: codes for a nexxtech tv remote control 3 in 1
Wiki works, folks.
http://kbase.x10.com/wiki/Four_Digit_Universal_Remote_Code_List
All the codes for Nexxtech Universal Remotes, including Panasonic.
Cheers!
Anonymous
  • Posted on Feb 01, 2009
SOURCE: code for Magnasonic TV
I have magnasoni TV 14`` and I have Unversal remot RCA in need some help for codes thanks
Anonymous
  • Posted on Mar 20, 2009
If the GE doesn't have a code scan function (similar to ExpressVu remotes) then you can always buy a programmable remote such as the Logitec Harmony. I tried it and it works fine on my Magnasonic GCT5501.
I purchased a universal rca remote. On the back card it listed as one of the brand name tvs magnasonic which is my tv. When i got it home there was no code listed on the paper inside for my tv. I tried...
Hi Bonnie,
I understand your frustration. RCA / Thompson Consumer Electronics has made dozens of different model universal remotes control devices. Without knowing your particular model number, it's hard to give a good answer.
I found a list of RCA codes here, and some others elsewhere - but none included the Magnasonic brand TV you have. If you have gone through the code search feature of the remote without any luck, it is probably because the TV is not supported by the RCA remote control. Not every TV, VCR, DVD, etc. is supported.
You may find that you'll have to return the RCA device and obtain a Magnasonic brand remote to operate your TV. You can view Magnasonic's Customer Support page here.
1helpful
Have all for one 4110 - need code for magnasonic
http://www.hifi-remote.com/ofaold/tvcode.html
MAGNASONIC 017,019,030,153,154,156,193,093,179
Should be one of these. If not try the website.
I cant set my universal remote to my magnasonic tv
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
2helpful
Magnasonic mctv1311 remote control code
Go to remotefinder.rca.com/default.aspx?site=rca for the correct codes (there may be more than one for each remote and try them till you find the right one).
1helpful
Code for Magnasonic TV
39helpful
10answers
Codes for a nexxtech tv remote control 3 in 1
Wiki works, folks.
Cheers!
36helpful
6answers
78helpful
7answers
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
