Question about Frigidaire ATF6000ES Front Load Washer
How do i remove black mold on gasket - Frigidaire ATF6000ES Front Load Washer
  • 4,323 Answers
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
  • pstanhope Feb 07, 2011
    I bought the Afresh and followed the instructions, running 3 tablets in succession through a normal load cycle. The washer smells better but the black remains on the gasket. What do I do. Some of it will rub off but not all.
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
Is ge doing anything about mold issue in their refrigerator model zir36nmarh
It is very easy to prevent and/or remove mold once formed.
Mold usually forms around the freezer doors an the door gasket. This usually happens in a humid climet when the "Energy Savings" mode is on. That causes sweating on the door frame followed by mold and black residu.
PREVENT MOLD BY TURNING THE ENERGY SAVINGS OPTION OFF!
You can usually turn it on during the winter, when home heating is running and humidity is low.
Remove mold from door gasket by applying any spray cleaner that contain Bleach or just use towel with bleach. For very dark stains, allow the bleach to stay for about one hour, it will remove most stains
After cleanup, using you finger, redress the door gaskets with a very light coat of common Petrroium Vaseline. This will leave the door gasket soft and protected for a long time.
Jun 02, 2014 | GE Refrigerators
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Mold around the front gasket
    u can use vinegar .. it will help to remove mold easily. u can use for clothes as well and even washer.
    Jun 19, 2017 | Frigidaire GLTF2940ES Front Load Washer
    The gasket on the washing machine has black mold on it and smells horrible. Do I have to replace this? Is it covered by warranty?
    Hello
    Simple green will get that mold off.Its up to you if you want to replace the gasket.I dont think the warranty covers mold or gaskets.
    Apr 12, 2010 | Kenmore 45087 Front Load Washer
    My Nexxt Washer has a black residue on the front gasket.
    The black is not algae it is mold. The only way to fix it is to replace the gasket/seal.
    Feb 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
    Mold on gasket; front lint trap clogged; washer reeks
    run an all hot water cycle using hilex bleach should kill the smell and mold
    May 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Black mold
    YES GETTING RID IF THE MOLD WILL HELP YOUR PROBLEMS BUT YOU WILL HAVE TO GET RID OF ALL THE MOLD AND ALSO CONSULT YOUR DOCTOR FOR A CHECK UP SOME MOLD SPORES CAN CAUSE SERIOUS DAMAGE
    Jan 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Frigidaire ATF6000ES Front Load Washer Logo
    231 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
