Question about RCA P61940 61" Rear Projection Television
Tv doesn't come on. when tring to turn on you hear a buzz then it turns back off. Could it be the power supply board?
  • RCA Master
  • 8,457 Answers
No,check for loose FBT-flyback tranformer connections a big black block of a plastic with a wire to a board section call highvoltage deflction board area.Useally the FBT is dead,require replacing and trouble shoot the deflection board area for other dead parts.Get quote prices from shops.Must hire a tv Tech. must do alot trouble shooting and replacing components.
Posted on Jan 01, 2011
I have a sylvania 32in replacement tv circuit board model srt2232s It doesn't turn on anymore , fuse is good , buzzing coming from a transistor I think any thoughts . Thanks
Hi there, sorry to hear. That "buzzing" you hear is most likely that power supply onboard, pulsing in a failure mode such as a current limit situation. Check for shorted rectifiers, and the common bad capacitors.
Jan 21, 2015 | Sylvania Televison & Video
NS-LDVD32Q-10A buzzing noise
Try another input and another source such as a DVD player. If you still get the buzzing sound, you could have a faulty power supply output or a fault in the audio circuit of the main board.
Jan 27, 2013 | Insignia NS-LDVD32Q-10A LCD TV
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
When i turn the tv on it attempts to go on but then you can hear the on/off switch a second time and it doesn't turn on
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Sony KP-51WS500 51" Rear Projection...
Samsung plasma tv pn42a400c2dxza. when i try to turn it on it starts making clicking sound than it starts buzzing. i unpluged everything from the power supply and the buzzing sound stopped. but when i plug...
This problems is the power supply board is causes and the problems.Try website like Ebay.com buy a whole refurbish power supply board for the replacement,will solved this problems.
Nov 29, 2010 | Samsung PN42A400 42 in. Plasma TV
Plasma Television won't turn on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Jul 02, 2010 | LG 42PQ30 42 in. Plasma TV
I have a Toshiba 52HMX94 rear projection T.V., i've had it for 4 years, replacing bulb every year. I now have another new bulb, but when I turn on the T.V. i hear a buzzing noise from the rear, and then...
Your TV requires ballast power supply board that gives you buzzing noise when TV turns ON.
Ballast supply board is available in Part Store and replacement of that board requires expertise.
Jul 23, 2009 | Toshiba Televison & Video
Buzzing sound on Vizio Plasma TV
likely supply failure or shorted pannel driver. u should be able to unplug the pannel boards from the power supply. if the buzzing stops than its the pannel boards otherwise its supply.
Dec 05, 2008 | Televison & Video
My flat screen tv is making a buzzing noise
my flat tv is hot when used after 30 min. or so
Sep 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sep 07, 2007 | Sony KV-35S66 35" TV
RCA P61940 61" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
