Question about Honeywell Heating & Cooling
How to set the night and day control - Honeywell Heating & Cooling
  • 2,133 Answers
Night symbol half moon and day symbol sun
Posted on Jan 02, 2011
How do I stop the heating coming on during the night?
Set automatic day and night temperatures. Forget about manual setting. Your furnace will start at night only to maintain the temperature you set. However, there is a minimum threshold where your furnace will start regardless of the temperature you set if there is a sharp drop in temperature.
Jan 31, 2017 | Heating & Cooling
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
http://waterheatertimer.org/How-to-set-timers.html
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
Sep 17, 2014 | Hardware & Accessories
Minecraft cheats
The commands are as follows.
/time set day
/time set night
Enjoy.
Nov 17, 2013 | Computers & Internet
My 2000 Toyota Corolla headlights will not turn on during the night, and stay on during the day
Your Corolla has daytime running lights (DRLs). A photocell determines whether it is day or night. Your DRLs turn on automatically in daytime without you operating the light control ("headlight") switch. Your DRLs are actually your headlights on low beam. At night, the photocell senses it is dark and disables the DRLs. When you set the light control ("headlight") switch to HEAD, the head relay closes and the headlights should turn on. Since they don't, I suggest opening the engine room junction block and checking the 40A MAIN fuse and the 10A LEFT HEAD (UPPER) and RIGHT HEAD (UPPER) fuses. In engine room relay block 5, check the 10A LH-LWR HEAD and RH-LWR HEAD fuses. Replace any blown fuses and the headlights should be working normally again
Sep 29, 2012 | 2000 Toyota Corolla
I'm using tes824 panasonic, my boss ask me to set guard house phone ring after office time, curuently day time guard house phone not ringgi at working time. how to do it ? TQ ya
Somewhere in the box, you have a DAY/NIGHT/LUNCH set of ringing controls and a clock or code to control it. In our TA's they are system programs 006 and 007 for clock control and times and 408-410 for ringing. YMMV :-)
Carl
Apr 13, 2011 | Panasonic KX-T7633 Corded Phone
I would like to have temp on constant all day and reduce temp at night in manual mode having trouble to do this. the control panel wants to set times and days all i want is constant.
Set your desired tmperature during the day and press hold. Then at night you will have to set it back and then again also press hold.
Feb 22, 2010 | Heating & Cooling
Regeneration is nightly as oppsoed to the prrprogrammed 14 days
"DAYS00" indicates it is set to run every day. You may have lost power and it reset to factory settings. If the Gold series softener you have is the Aqua Sensor model (this is a probe in the resin tank that senses a change in the water chemistry and sends a signal to regenerate) the probe can get coated with iron and will either send NO signal or a Constant signal which will make it regen every night.
Usually a Gold series softener is either set up as metered or aqua sensor. There is an option for an override (such as 14 days) or it can be set up as a time clock model. Unplug the softener for 2 minutes and plug back in, re-program the controls to "DAY14". Make sure what the system is suppose to be set up as, Meter, AS, Time Clock.
Here is a link to Culligan for the Gold manual.
http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/
RJ
Jan 26, 2010 | Culligan Sediment Water Filter
How do you program different time for day & night outlets? When you program setting 1 how do you know if it is day or night.
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 05, 2010 | Coralife Zilla Aqualight Power Center
Day and night heater and a/c unit heater would go
first try to pull the little white button out, it is a manual control button, and the out position is auto. If that does not work try taking off the cover, lightly hold the dial down while you adjust the settings. they are on the side of the dial, first setting is the off pos. set to 90, second is the on pos. set to 125-135. then put cover back on, while being careful not to push the button in.
Apr 03, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Kxta824 disa help
Your system has 3 modes of operation, day, night, and lunch. Lunch doesn't have to be a specific time, and you could manually switch between the 3 modes. Most small customers don't even use NIGHT mode, except to control the voice mail system.
Full programming instructions are beyond the scope of the free forum, but in section 3.1 of the programming tool, you set the mode of the trunks for day/night/lunch. No matter what the status of the auto switching to day/night mode, you can still manually switch to lunch by dialing 782 from any phone, and manually switch back to day/night mode (780/781) to turn DISA mode on or off.
Now, you still can have different OGM's for day and night that will automatically work, and manually use the lunch to control the applicaion of DISA. Even if the receptionist steps away from the desk, you can go into 3.2 and turn on some delayed ringing, or anyone can put the system back in day or night mode.
Carl
Jan 30, 2009 | Panasonic KX-TA824PK Phone
Heating & Cooling Logo
98 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
