Question about LG LUV200R Bagless Upright Vacuum
Where can I find an agitator belt for my LG LUV200R upright vacuum?
reddevil6
  • 1673 Answers
SOURCE: hoover u8147-900 upright vacuum
Either the brush rolls are bad, at the ends, or the gear/motor asm. is bad.
Posted on Jan 29, 2008
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
Posted on Jul 15, 2008
  • 4 Answers
SOURCE: I have a kenmore upright vacuum model
the reset is for your safety no belt ,probly a direct drive motor issues ,maybe the brushes it is detecting a short and pops the reset.
Posted on Apr 14, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same issue. The holder for the micro switch is very weak and will open up and allow the switch to come loose, and in my case the was not enough slack in the wire. I unplugged the unit, pressed the pedal and laid it down. Open up the bagger door and remove the bag and filter. Remove 4 screws in the bagger compartment, remove 2 screws by InteliClean indicator lights, remove 4 screws on the outside close to the light. You will be removing the blue upper case. Remove the upper case and look on the right where the lower agitator section pivots. There you will see a micro switch. I ended up lifting and tilting the lower pivot section to the side, repositioning the switch in the holder, and then wedging a full glue stick (not melting but wedging) between the white plastic housing and the switch holder. This added the strength needed to the switch housing to hold it in place. Put it all back together, install the filter and bag. This fixed mine. Good Luck.
Posted on Feb 27, 2010
Parts
Hi, it's Allie from Crucial Vacuum!
The agitator, also known as roller brush or brushroll, is located in the floor base.
You can purchase direct your replacement agitator, filters, and belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/lg-kompressor-luv200r-luv300b-roller.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 18, 2014 | LG Kompressor Upright Vertical Cyclone...
Agitator manual
If the belt must be stretched to be installed it will lose elasticity after a few months. It might be as simple as replacing the belt. If that doesn't fix it you will need to dig a little deeper to find out why the belt is not spinning. Some vacuums have a switch that shuts the brush roll off and on, the switch might need serviced. Some vacuums have a separate motor that turns the belt, if so is the motor working?
Oct 31, 2013 | LG LUV300B Bagless Upright Vacuum
Suction
If the motor comes on then either the shaft connection at the fan is loose or the belt to the beater bar is bad.
Jul 12, 2013 | LG Electronics Kompressor Pet Care Upright...
Hose has no suction
I have found uprights absolutely choked with pet hair. Check the suction path
Sep 22, 2012 | LG Electronics Kompressor Pet Care Upright...
The alarm on my machine keeps sounding; even though I have cleaned the filters, emptied the dust bucket, its driving me mad as I rely so much on this machine; with dogs, cats and children and a farm h
Please check the suction on your machine? Is it strong? It may be that you have a clog, particularly since you have dogs, cats and children!
It suction is fine, have you checked the rotating roller brush? If the point of pickup is poor on your floors, you may need to check your belt. You may have picked up a large object that has affected the tension in the belt. Visit here for your belt: http://www.crucialvacuum.com/LG-Kompressor-Vacuum-MAS61842501-Belt-p/lg_vacuum_belt_5eph271.htm
Oct 18, 2011 | LG Electronics Kompressor Pet Care Upright...
When I use the vacuum it smells like something burning but it does work. How do I fix this? Thank you Sharon Post
Hi ssharonxxx...
Sounds like you have hair,strings,debris caught on the beater bar and it is causing the belt to burn on the beater bar or motor.
Remove the bottom of your vacuum and clean,oil and replace the beater bar, that should solve your burning smell problem.
Please take time to rate me thumbs up
Sep 14, 2011 | LG Electronics Kompressor Pet Care Upright...
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
LG LUV200R Bagless Upright Vacuum Logo
229 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Ed Mac
Are you a LG Vacuum Expert? Answer questions, earn points and help others
