Question about Whirlpool Duet GHW9150P Front Load Washer
F 02 is being displayed on washer. Can the washer be fixed from the front of machine.
  • 4,323 Answers
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Posted on Jan 01, 2011
Washer is flashing a signal of 02 F and beeping
F02:
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washer is no completing cycle. I see a F 02 code falshiing. How ca i fix it?
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects HERE"S HOW
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
I have a manual and repair photos HERE
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error 02,F when washer is draining.
F/02 Error
Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check the electrical connections at the pump and make sure the pump is running. globul1a.gif Check the drain pump filter for foreign objects. globul1a.gif If the above does not correct the problem, replace the pump.
Nov 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is displaying an "F02" message. What does this mean?
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
display.
minutes later the “F/02” error code will be displayed.
or kinked.
4. Check the drain pump filter for foreign objects.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet will start washing but then stops and displays 02 then f.
it means your washer isnt pumping out the water...check the drain filter for a clog or an object in it if this doesnt do it call for service there is nothing you can do to fix it
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F 02 Error Message
Hi!
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed.
Potential Causes
If still the problem persists then you need to replace the pump.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
02 f error code
F/02 code appears because :---------Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
to resolve this problem  :----------
  • If the above does not correct the problem, replace the pump.----------------
  • rate the solution.
thanks.
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 code
F 02 means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed. Potential Causes
Jan 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
