Says Lr - Washing Machines
  • 4,323 Answers
Hi
Lr means locked rotor. This issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
It said Lr on screen and stops
LR = Locked Rotor on the motor. Many things can cause this. Please contact me, with more details willing to help all I can.
Apr 12, 2014 | Maytag Neptune MAH5500B Front Load Washer
Dtc c1073
depends on the car im guessing that the chrysler one is the one ur looking forChrysler:ABS Pump Motor Control CircuitDodge:ABS Pump Motor Control CircuitJeep:ABS Pump Motor Control CircuitFord:LR ABS Valve coil short to ground.Mercury:LR ABS Valve coil short to ground.Lincoln:LR ABS Valve coil short to ground.Mazda:LR ABS Valve coil short to ground
Nov 18, 2012 | Mitsubishi Cars & Trucks
I have a 2000 Ford Taurus sedan and the back driver side window is the only one that has power, what could be the problem?
power at the back driver's door switch or at the driver's master switch? if power on the master switch cotrols the lr window then you most likely have bad master window switch. if the lr door switch is used to control the lr window then most like you have three bad window motors.
May 26, 2012 | 2000 Ford Taurus
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
What does error code Lr mean
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning. Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to. The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. could also possibly be the Water Inlet Valve w/Thermistor #22003834 needs to be replaced due to having Well Water with lots of sand, in the water it is not closing the valve properly allowing water to continue filling the tub, causing it to read the load being too heavy and also leaking out the front door
Nov 27, 2010 | Maytag Neptune Washer
Lr message
THIS WEBSITE IS VERY USEFUL FOR YOUR MACHINE
http://www.applianceaid.com/neptune8.html
HERE IS THE OUTLINE FOR THE CODE LR
Lr Locked Monitor Rotor Based in signal information from motor control board, the machine control board senses the motor is not turning when requested to run 1.Run motor control board diagnostic test. 2.Check motor control board for damaged components.
3.Check wire connections in harness leading from machine control board to motor control board.
4.Replace responsible component.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
