Question about Vehicle Parts & Accessories
Polarstart ps-3155 blue light is solid and remotes are no more working Got light on remotes when pressing button but nothing happen on car side, hopefully no startkiller so i can stil use my car But can't use the remote Looked everywhere for a tiny swich :-( nothing Found the control box followed many wires but no one run to a swich Need help to make it back to life
RAIN3R
  • 5 Answers
SOURCE: changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
  • 131 Answers
SOURCE: remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
Posted on Apr 16, 2009
SOURCE: Daewoo DF4700P
Model No DF 4700P
Posted on Jan 02, 2008
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
myob247
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
What if blue light is off no flashing nothing
Lock the driver side door then open it with key that might reset you anti thief to your remote.
Apr 06, 2016 | Remote Start System
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
Tv won't come on
unplug, remove back and check to see if any bulging capacitor caps, if so, replace them....worked for me on Vizio
Feb 09, 2012 | Televison & Video
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
My screen is frozen in updates. It tells me to press ps button to use my controller. What is this?
Its the very middle button on your playstation remote. If its saying press the ps3 button on your control its possible your ps3 is not frozen but your ps3 remote has just turned off..
Press the very centre button and check the lights on the top of the joypad. Are any lights lit solid? Once the light comes on solid the controller is active. If these do not light youll need to charge your ps3 remote with the usb cable that came with the ps3.
Also if your ps3 remote is lit for number 2, hold down the ps button, very middle for about 5seconds. Should have an option for reassign controllers, select that and put your controller to number 1.
Hope this helps
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Lamp light stays solid red . i already replaced bulb. any solutions?
Check your owners manual for diagnostics. You can find all documentation for your VT595/695 projector on the NEC support site.
The users guide indicates that the lamp timer needs to be reset. Instructions can be found on page 49 of the users guide.
Press and hold the HELP button on the remote control for 10 seconds to reset the timer.
Feb 05, 2010 | NEC VT595 LCD Projector
Only Power On light and Light on far Right come on
remove remote controll batteries and replace it , possibility get new ones
Apr 06, 2008 | Sony Blu-ray/dvd player BDP-S1
Sep 28, 2007 | Samsung TV Remote Control
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Vehicle Parts & Accessories Logo
655 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
