Question about Kenmore 28015 Bagged Canister Vacuum
I have an open in the black wire leading down to the carpet sweeper (after the handle), thus the motor wont turn on. how do i get to the wiring to re-run a black wire?
  • 694 Answers
Did you test the wire with the switch in the "ON" position. If not, try it before opening the handle.
The problem is more likely to be a worn out or broken switch, including a reset switch.
Also try connecting the hose directly to the power nozzle. If it works, then the problem is problem a loose or burnt out connection in one of the wand connections. Check connections for discoloring.
Posted on Jan 01, 2011
Electrolux epic 6500 carpet sweeper cuts off and on while vacuuming
Your description indicates an internal break in the wiring carrying the current to the sweeper motor, though it could be just a loose connection.
The unit will need at least partially dismantling for testing and examination.
Feb 27, 2018 | Electrolux Vacuums
HOW DO I HOOK UP THE WIRES TO THE MOTOR I FORGOT
You should only have 4 wires to hook up to an Oreck motor. The black wire from the cord coming into the back of the motor housing will be attached to the closest lead when the motor is in it's normal position. Most of the time there will be a black dot next to the terminal. On the other side of the motor you should have two white wires that should be connected together, one from the same cord just mentioned and the other one coming from your lights. Those two wires should also be connected to the motor where there is a black dot beside the terminal. Your last black wire coming from the lights should go to the terminal next to where the white wires are connected or to another terminal that is on that side of the motor. Hope this helps!
Mar 14, 2015 | Oreck Single Speed Handle Assembly - White...
How do i replace the on off switch on Hoover U6485900
Make sure the power cord is disconnected! There are two sets of three screws one needs to remove. The first set hold the handle assembly to the sweeper body (there are two near the back of assembly and one in front). The second set is inside the cavity that hold the vacuum powered cleaning tool. There are two at the bottom of the cavity and one at the top. Refer to the Assembly Instructions in the Owner's Manual for help. One can then remove the power leads from the on/off switch, push the switch out, and insert a replacement switch. Pay attention to the color of the wires because some switches apparently work with models having 2 black wires (H-28161075), others with a black and yellow wire (H-28161074), and others with connectors to the wires. Reassemble the sweeper reversing the dis-assembly process outlined above.
Jan 02, 2014 | Hoover U6485900 Bagged Upright Vacuum
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
My oreck upright model xl3640 is not turning on. A clothespin was accidently vacuumed up, and the machine was immediately turned off to remove it. The bottom panel of the machine was taken off to remove...
the Oreck XL3640 power switch goes bad most vacuum service center can order a new switch it has 3 wires remove screws from handle to get at switch hook up wires to new switch color code of wires of wires are black white black just put on right terminal on switch _1284.jpg
Mar 08, 2011 | Vacuums
Vacuum wont spin when on carpet but will spin if tilted off the carpet
Remove the bottom plate of the sweeper. Remove the sweeper brush roller and clean the end bearings of debris. Oil the bearings lightly with 3-1 oil or similar machine oil. Clean the motor shaft with alcohol as well as the brush drive area, and the inside of the drive belt. Test on a carpet for improvement--if still stopping, replace the rubber drive belt. Hope this helps!
Nov 21, 2010 | Bissell 3920 Bagless Upright Vacuum
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
http://www.aerushome.com/storelocator/
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Oct 12, 2010 | Electrolux Central Vacuum
The handle broke at the base of the sweeper
Could this mean the wand socket broken on the motorized carpet head. Please provide make and modell
Sep 03, 2009 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Bissell 9400 Carpet Cleaner
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
May 13, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Kenmore 28015 Bagged Canister Vacuum Logo
43 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
