Question about Lexmark E260dn Laser Printer
I cannot get Avery 2180 labels to print on the proper label. They donot print properly or in sequence. i've not tried other file labels but address labels print fine.
  • 161 Answers
SOURCE: okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Posted on Aug 06, 2007
SOURCE: lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Posted on Jun 11, 2008
sflummox
  • 72 Answers
SOURCE: cannot print avery labels,
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Posted on Jun 25, 2010
  • 286 Answers
SOURCE: Lexmark T640 won't print on label sheet a SECOND time...
Don't put used label sheets through a laser printer. Just because you had it working like that doesn't mean it's a good idea. We've had many laser printers in our shop here where the owners did that and eventually the edge of one of the removed label areas will get stuck on something (usually the fixing unit) and completely ruin the fixing unit requiring it to be replaced. Only use "Laser Printer Labels" and never use used sheets.
Posted on Sep 24, 2012
SOURCE: How can I make printer recognize refilled cartridge on lexmark prevail pro 705
Consider the facts. If it's "manmade" then there's a way around it. This is one of the most unethical moves on the part of any company to pull such a stunt as this to FORCE people to use their product. I see these little chips and will attempt 1 last time to cover them, or use a magnet and burn them out, or the Lexmark is GONE forever.
I used to have a printer that accepted Walgreen's refills with no problem.
Posted on Nov 29, 2012
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
I have an Access file with 132 names with addresses. I want to print them on Avery labels. How can it be done?
Avery labels have an ID# that when entered into the Avery site will supply you with the page format for your Msoft Office software.
Dec 14, 2011 | Avery 5160/8160 compatible (100 White...
Hi. We are trying to use an avery label 22807 and also 22806 for a label factory logo we created. We need measurements/diameters so that we can print on these labels. They keep printing wrong. ...
If you are using Microsoft work to print the label, then follow the link below to Avery's website. The link is to their find a template, type in the label number in the Product # or Keyword search box and it will take you to a down load for that label. Click on the download, you will be asked for some information before the download begins. Follow the instructions on the next page (save the file and remember were you saved it). When you open the saved file it will be in Word and you can go from there.
http://www.avery.com/avery/en_us/Templates-%26-Software/Templates
I hope this helps you out.
Jul 22, 2011 | Computers & Internet
How do I set up my HP 3050 to print Avery labels 5160?
You need to download the templates they have online and edit them in Microsoft Word. Here is a link to the template:
http://www.avery.com/avery/en_us/Templates-&-Software/Templates/Labels/Address-Labels/Address-Label-30-per-sheet_Microsoft-Word.htm
Click the blue download template button and follow the instructions.
Mar 31, 2011 | Office Equipment & Supplies
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I am trying to print labels and they keep coming out off center
You most likely need to download the proper template from the manufacturer of the labels your using. Look on the package of labels for the web page for them if you don't have the package the company name and template required is usually printed somewhere in the border of the label page. For example Avery avery.com. If the template is not listed you can search the library of templates for one that looks like your labels. Download the template. This should solve your issue of improper centering of the label. Your likely currently trying to use one of the templates supplied by Microsoft, but they rarely work with most labels.
Aug 03, 2009 | Microsoft Windows Vista Ultimate Edition
Can I print a cd on my canon mp510 printer?
You need to download a CD cover creator software. If you also want to print your own CD label stickers (round ones for the disk) you will need also to buy CD avery templates.
Here is the software:
Download Super CD Cover Maker v2.0.0
Cd Cover Label Software Freeware
CD Cover Designer 2.5 {freeware} at Damn Printer
Free CD/DVD Covers Software Downloads
Cd covers Free Download
Easy CD and DVD Cover Creator and Label Maker.
Here instead you can buy cd labels:
Avery Labels, buy Avery office products, Avery CD Labels
Sep 06, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Printing avery labels
You need to change the paper settings from plain to something thicker. The toner is not being heated properly for it to fuse to your paper. It needs to run at the correct speed and temperature in order to adhere properly.
Set it to a heavier stock.
Apr 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Lexmark E260dn Laser Printer Logo
82 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
