Question about Maytag EPIC MFW9700S Front Load Washer
I am trying to run my first cycle on my maytag 4000 series front load washer and i keep getting F 35 blinking in the display, how to solve that?
  • 4,323 Answers
Hi
Error code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component detected by the Steamer Electronic Board. Please check whether the pressure hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not plugged. If this doesn't resolve the issue then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch, you would need to replace it. Please post back in case of further assistance. Hope this helps...
Daniel
Posted on Jan 01, 2011
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
I keep getting error codes on washer and will not continue the cycle
That code in most cases means you have a bad pressure switch. It is generally $99.00 (approx) for the cost of the part.
May 11, 2012 | Maytag Performance MHWE500V Front Load...
I have a maytag front loader 4000 series and the control lock light keeps flashing and wont go off..
press and hold the lock button down for 3 seconds and it should unlock. if it does't then the electronic control is malfunctioning.
Jul 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I have a MayTag 4000 series washing machine that is 6 month old. Sometimes the water pump is working but then it does not spin. Then one hour later the washing machine finishes the cycle but the clothes...
the problem with the washer is simply the panel or it might be the belt if the machine is not direct drive machine or call ur technician alson to run a check on it
Jun 28, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag 4000 front loader control lock is flashing, washer wont start cycle
have you ever tried unplug it and wait 20 secs and then plug it in again? I hope it works, God bless
Jan 26, 2011 | Maytag MHWZ400T Front Load Washer
I am getting an error NF during the washer cycle run. The cycle will not complete and has to be restarted. What does this error message mean?
Hello
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
SPIN CYCLE PROBLEM
Replace both the wax motor (part of door lock),2nd,at the same time replace the main upper Control board.You will solve this problem.
May 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
