Question about Bosch Dishwashers
Our Bosch SHU43C06UC/17 dishwasher stopped working properly today. The power scrub cycle starts at 115 and counts down to 112 and then stalls -- no sounds of water entering the unit... no further counting down The regular cycle starts and shows 97 and counts down to 94 and stalls. no sounds of water... no further counting down. We hear a constant buzzing sound. Can you help?
  • 641 Answers
SOURCE: shu5312uc bosch dishwasher
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Aug 02, 2007
dutchman05
  • 487 Answers
SOURCE: Our Bosch Dishwasher no longer
Unfortunately that indicates a control module problem. Only fix is to replace that
HERE you can find the parts and drawing
Posted on Nov 30, 2008
  • 11 Answers
SOURCE: We have a Bosch dishwasher
My father-in-law has a Bosch and they had the same problem. The tech guy said it was not heating properly and that caused it to continously run because it won't tick down the timer if it doesn't reach a certain temp, so try turning your faucet as hot as you can, right before you turn on the dishwasher and see if that is the problem, if not the heating element might not be working properly. If you still have a warranty, try to get them to see and fix it, otherwise, get a repairman to check it out. You can also turn up your hot water heater, but not so hot it would be dangerous to use, but enough to get the temp up. Otherwise the heating element might need to be replaced.
Posted on Jul 28, 2009
jan mczeal
  • 632 Answers
SOURCE: water not draining
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Posted on Sep 04, 2009
arikrom
  • 528 Answers
SOURCE: bosch shu43c06uc-17. Our dishwasher turns off mid
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Posted on Jan 01, 2010
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
MY BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. I HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT I...
Hi gwmkjm,
I'm Harvey the Master Plumber.
Your question is: YOUR BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. YOU HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT YOU STILL CAN NOT GET IT TO TURN ON. AT ONE TIME THE LED LIGHT LIT UP FOR A BRIEF SECOND, BUT NEVER AGAIN. ANY OTHER SUGGESTION?
Yes. 9 times out of 10 it's a loose or broken wire in the d/w junction box under the d/w behind the kick plate on the right. Make sure to turn off the electric before you expose the wirenuts. Remove them and install new.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Bosch Dishwashers
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
Nov 20, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
Will turn and show count down numbers on any cycle,but thats it will not continue.
Might be stuck in a diagnostic cycle. Have you turned the power off and back on?
Press and hold "Regular Wash" & "Power
Scrub Plus
" buttons. See if it makes any difference.
Please post a comment to confirm how it is going.
Nov 04, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch Dishwasher model #SHU43C06UC/17 in 5 years old and has been working great and all of a sudden last week it stopped working. When you try to start a new load it will start the timer, but the...
Welcome to FixYa.
I would first run a diagnostic to see what error is presented and in turn will direct which way to focus the repair.
Try this and then let me know what you find aa a result...
This diagnostic posted below should guide you, let me know if it isn't clear or you don't understand something.
Sep 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu43c06uc-17. Our dishwasher turns off mid cycle, and now leaks from the bottom.
Nov 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Dishwashers Logo
90 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
