Question about GE X5 Digital Camera
Cannot get the flash to work. - GE X5 Digital Camera
I am not sure if it will work or not? However, I just hopped on ebay, and purchased a a flash repair part, and it was 7 bucks. Total with ship was only 13 dollars. Anyway, it is on it's way, so we will see if that remedies the issue.
Posted on Oct 21, 2011
  • Shajan RS
    Shajan RS Oct 21, 2011
    Please let me know the part you're referring to. Also please confirm whether the Camera is not set to any of the above mentioned modes.
  • 890 Answers
If the built-in flash does not function, then the camera flash may be turned off or it is set to Auto and will only flash when taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting situation, press the flash button on the camera (or touch-screen LCD, if equipped) until the forced flash icon appears on the LCD screen. The flash button has a lightning bolt symbol on it
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Posted on Jan 01, 2011
Why are Flash videos not playing on my computer,especially Firefox 30. Any suggestions?
You probably have to unistall flash on firefox.
  • Go to adobe flash download page. 32 bit or 64 bit for your system configuraton
  • Make sure you check that the latest version is available (which will show in the browser window)
  • Download the flash uninstaller. Scan with your AntiVirus
  • Run the uninstaller then reboot the system.
  • Then install the flash update download
Adobe Search flash
Uninstall Flash Player Windows
Jul 05, 2014 | Mozilla Firefox
Canon sx 150
Hi
1. The flash on this model Canon works only if you manually raise the flash. It does not rise automatically, and is only on the raised flash.
2. Flash on the module has a switch - it sometimes fails and then flash "does not understand" that she had to get involved.
3. Not working flash capacitor charging circuit - usually after any water
4. Flash lamp is not working - usually after a light blow
5. Command does not work (a piece circuit) from the processor to light the lamp flashes - after a blow or hit the water.
If you follow steps 1 - Raise the flash and the camera is turned on in the menu mode - "shoot with the flash" - but your flash does not work - the rest can fix broken only engineer to repair.
Oct 23, 2012 | Canon Powershot Sx150 Is 14.1 Mp black...
Flash will not work
Before you give up on the camera:
There are many setting that can affect whether the flash works or not.
You may have inadvertently set something that is stopping the flash from working.
Get out your User Manuals and use the index at the back of the book.
Look for something about "Resetting the camera".
This will reset the camera to factory specifications.
Then see if the flash works.
If that does not work ... recharge the battery and try again.
If that does not work, the flash is likely dead.
May 30, 2010 | Canon PowerShot A590 IS Digital Camera
The flash does not flash. Camera works without the flash.
I reviewed the menu settings and made a change to the flash option setting. Some how the function was turned to the off position!
Reading your posted comments gave me the idea to check that out!
Thanks, TW
Aug 24, 2009 | Canon Cameras
Flash does not work
Ok,
Flash unit is defective and needs to be replaced as per following part number... (if you have camera repair experience then can do it your self because electric shock risk in involve in flash unit handling)
A-1249-950-A ..ST BLOCK ASSY
Above part is available in Part Store.
Dec 26, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Minolta Maxxum 3200i Flash does work
Try to short out the flash and see if the flash flashes.
Remove flash from camera.
New or fresh bateries installed.
Get wire with insulation and remove both end bare to 1/4"
Turn on flash and wait until light turn green or ready.
Touch one lead to center of flash pin, touch other end to the outside(rail on the side) pin.
Flash should discharges.
atdlee@netzero.com
Jul 28, 2008 | Cameras
Auto Flash 200x doesnt work ???
CoolSmith,
try a non dedicated flash unit, if the flash works then the 200X is not compatible to the xg1
if the flash did not fire, there is a circuit problem. there are no new parts for this model.
Mar 09, 2008 | Minolta XG-2 35mm SLR Camera
Flash not working
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
Feb 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Canon EOS 1000F in-built flash unit
Set camera body for Internal Flash for Pop-Up Flash.
Set camera body for External Flash for parked flash on Hot Shoe.
atdlee@netzero.com
Nov 08, 2007 | Canon EOS-3 35mm SLR Camera
GE X5 Digital Camera Logo
290 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
