Question about HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1 X P4 2.8 GHZ - RAM 1GB - HD 1 HP (PJ143USABA)
When I turn on the computer, the date and time are incorrect, and mentioned that it is the battery. I need to buy a new or can be fixed?
  • HP Master
  • 6,771 Answers
You need a new cmos battery for your computer, located on the motherboard, it will correct your date and time issues when it is set up, and yes it is worth fixing. Take it to shop you can trust.
Posted on Jan 01, 2011
My system time and date is not set
Go into the BIOS settings then to the Date and Time and set the Date and Time, Save the settings and Exit.
IWhen you boot up later and the Date and Time is incorrect then the BIOS battery is flat and a new replacement battery is needed. The BIOS battery keeps the laptop's configuration plus the Date and Time settings unless the battery is flat.
Apr 16, 2012 | Dell Inspirion Computers & Internet
Time and date are not set correctly
When the Date and Time is set in the BIOS setup or in Windows and when you boot up next time and the date and time are incorrect then the problem is a flat BIOS battery. A flat BIOS battery cannot keep the Data and Time stored in the BIOS. Replace the BIOS battery and set the Date and Time etc and the problem will be fixed.
Apr 04, 2012 | Toshiba Tecra S3 Notebook
My time and date are incorrect and the startup screen is black BIOS requesting me to adjust the time.
If you are using Windows XP/Windows 7 all you have to do is right click on the time in the taskbar, and click properties. Click on "synchronize with web" (or something to that effect) and it will sync to an online server, thereby fixing the problem. I don't know exactly how to do it, since I am not running Windows, but I've done this before on my mom's computer. :)
Mar 13, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Date &time change every time I turn on my pc.why? how to fix the problem?
Hi elfridapanot,
The CMOS battery in the motherboard is be weak. Thats why the time resets every time you start you computer. Open up the computer case, and look for a battery on the motherboard. Take it out carefully and replace it with a new battery. Then start your computer and set the date. Next time when you restart, the date will not be reset.
If this information was helpful, please rate it.
Thank you for using Fixya,
Arun Zac
Dec 07, 2010 | Computers & Internet
My computer will not keep time. is there a battery that needs to be replaced to fix this.
Turn the computer off.
Disconnect the AC power.
Remove the side-panel to expose the motherboard.
Look for a silver-coloured object, about the size of a US $0.25 coin.
This is the battery that helps the clock on your motherboard keep the correct time.
Look closely: one side of the battery shows engraving, and the other side (which you cannot see is blank).
Gently remove the battery.
Take the battery to a computer-store, to buy a replacement.
Press the new battery into the socket, orienting that engraving to match the engraving on the battery that you removed.
Restart your computer.
Press DEL to enter BIOS SETUP.
Click "Load BIOS defaults".
Reset the date/time.
Click "Save and Exit" from BIOS SETUP.
Oct 22, 2010 | HP Compaq Business dc7600 PC Desktop
My dell 1525 no power at all
Good luck with this colossal piece of junk from Dell. I had the same problem. Second Inspiron to do this. I ordered a new battery. The Dell techie was SO impressed that the battery lasted more than a year. It lasted a year and a half. Anyhow, new battery arrives, and it won't charge. They tell me it is probably the plug in and the motherboard. Nothing like spending over 500 to fix a computer that I paid 600 for that did not even live to see two years old. Did I mention that I will NEVER buy another Dell.
May 26, 2010 | Dell Inspiron 1525 Laptop
My computer's bios doesn't save anything
Here's the manufacturer info link
http://www.intel.com/products/motherboard/DG31PR/configs.htm
BIOS Loses Date and Time (or Changed Settings Not Saved)
A coin-cell battery (CR2032) powers the real-time clock and CMOS memory. When the voltage of the CMOS battery drops below a certain level, the BIOS Setup program settings stored in CMOS RAM (for example, the date and time) might not be accurate. If you find that date and time is incorrect or if you make BIOS setting changes but they are not saved, replace the battery with an equivalent one. Caution Risk of explosion if the battery is replaced with an incorrect type. Batteries should be recycled where possible. Disposal of used batteries must be in accordance with local environmental regulations.
To replace the battery, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Disconnect the computer’s power cord from the AC power source (wall outlet or power adapter).
  2. Remove the computer cover.
  4. With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the “+” and “-” on the battery.
  5. Install the new battery in the connector, orienting the “+” and “-” correctly.
  6. Replace the computer cover.
Jul 10, 2009 | Intel D915GAG Socket 775 Motherboard -...
Have to set date n time on every start of my computer.Already replaced the battery of the board.But no fruitfull result!
what you need to do is replace the CMOS battery on your motherboard.
unplug the power cord from the wall.
take the cover off your tower by removing the screws and sliding it back and up.
on your motherboard you will see a small ni-cad battery about the size of a nickel.
remove it from its clip and replace it with the same battery number. these are available at any radio shack, walmart, best buy, curcuit city.etc
rplace the cover and boot your computer. set your date and times one last time and it will stay now.
Good Luck
do not do this with the computer power on...
May 28, 2009 | Computers & Internet
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1 X P4 2.8 GHZ - RAM 1GB - HD 1 HP (PJ143USABA) Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
