I have been given a Grundig MD-P1 mini disc player and cannot work out how to use the control unit. any advice would be helpful. tankyou Andy
ronenfe
  • 91 Answers
SOURCE: md-h100 mini disc player
which remote control do you have? there should be an option in the remote to scan for the right code.
Posted on Mar 08, 2008
SOURCE: Code for remote control Medion MD 4689
The manual of the Medion MD 4689 remote I own states the following codes for Grundig TVs:
008 017 043 091 101 117 135 136 114.
Best wishes from Spain!
Javier
Posted on Jan 03, 2009
SOURCE: I've had a Pioneer SX-R9
can anyone tell the remote model nos for the PIONEER SX-R9? Thanks!
Posted on Mar 20, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: converting a sony mini disc into a mp3/audio cd
i understand (i've gone through 3 sony md recordable players & now i have about 15 - 20 md with good mixes from clubs/carribean islands beach partys) the only thing i can suggest is invest in another mini disc that is capable of playing the 74 min disc (and speed that was recorded) here are two sites to check out 1--http://shopping.yahoo.com/s:Portable%20MiniDisc%20Players and 2-- http://www.google.com/products?hl=en&q=mini+disc+player&um=1&ie=UTF-8&ei=OhkbSozEApC6tAOr9NCSDw&sa=X&oi=product_result_group&resnum=4&ct=title
Posted on May 25, 2009
SOURCE: My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Posted on Oct 13, 2009
Power
That is not a lot of information to go on, but I suspect there is a problem with the transport or heads which causes it to shut down. I've had similar instances with several of the MD Decks I've had.
On any MD deck if the complex play/recording head which is optical magnetic gets messed up you are probably better off to just buy another unit. The best use for a MD Deck with a bad head is to use it as an analog to digital converter or vice versa; if it has sufficient inputs to do so (the inputs vary with the model).
Sorry I can't be more specific with the limited information you have given. It is probably due to the stress of the head malfunctioning causing the shut down.
Jun 08, 2013 | Sony MDS-JE440 Mini Disc Player
Need user manual for grundig md 60 mini disc player
I checked Minidisc.org and could not find a manual for that one. I know MDs pretty well and had never heard of it.
Nov 23, 2011 | Sony Audio Players & Recorders
Is there any other remote that will work with Sony Mini Disc Player & recorder model mds je-320
Most Sony MD remotes will operate most functions on this unit, almost all of the Sony MD remotes are available on ebay even the rare ones.
Jul 01, 2011 | Sony MDS-JE320 Mini Disc Player
After edit a MD then MD Player show " Disc Error"
It is not writing the edit to the disc for some reason...
May 23, 2011 | Sony MDS-B5 Mini Disc Player
Do you have an address or phone number of someone in the North Island,New Zealand that repairs mini disk players please?? Cheers Marilyn
The only place I know of who repairs MD Decks are in Germany or the USA, In the USA Pro Digital of Philadelphia does. Check eBay Germany for MD parts and supplies, the seller there also does repairs.
I'm sorry I do not know anyone down under who does them, I'm also listing this as a reference for others who may need help.
In general if it needs fixing due to the age of most of these units, you are probably better off just buying another unit which works on ebay.
Apr 22, 2011 | Sony MDS-JE520 Mini Disc Player
MD player windows keep saying "no disc" when a disc is inserted. This started after the door starting getting sticky opening and closing. Any help would be great. Thanks
The little switch that detects the disc is inserted goes bad quite often on all of these sony home MD recorders. Do an online search as I have seen a step by step approach on it's repair. Make sure to UNPLUG the unit before removing any covers and poking-around inside. Good luck,
Jan 17, 2010 | Sony MDS-JE320 Mini Disc Player
Every time I load a disc the words 'disc load error' appear
Inside all MD players are a number of small pinswitches. These sense whether the MD is correctly inserted, whether the record protection tab is activated and whether the protective slide on the MD has retracted after MD insertion. On Other (portable) MD playback devices will also have a pinswitch which checks that the lid has been closed, but yours is slot loading so does not have this.
Pinswitches do not last forever as the internal parts can fail due to fatigue or due to misuse, and in every MD player which I've examined with the symptoms you describe the fault has either been a pinswitch or a faulty solder joint to the switch.
Without examining the unit though it's not possible for me to narrow down the fault any further but if you have basic electrical skills and tools you can use a continuity meter across each pinswitch to determine which one is not working correctly.
The part is cheap: original spares are usually unavailable but can normally be replaced with a generic item or bypassed altogether if the user is prepared to accept minor losses in overall functionality.
Note that a good used MDS-JE480 is still relatively easy to find: my first one cost me just £30 on eBay less than two years ago and since then I've acquired another which was listed on FreeCycle for the princely sum of zilch. Yamaha and Kenwood units are also knocking around although few of these have the MDLP capability of the JE-480. So don't bother with spending much on repairing your current unit without looking for another replacement first as it's likely to be the cheaper option.
Sep 18, 2009 | Sony MDS-JE480 Mini Disc Player
Converting a sony mini disc into a mp3/audio cd
Nov 25, 2007 | Sony Net MD Walkman MZ-N910 Portable...
79 people viewed this question
 Grubhead
Grubhead
