My touch pad is not working correctly; sometimes the functions work and sometimes it does not. I have tried rebuilding but it still does not consistenly work.
It may be because it is getting worn out because maybe if you press on too hard or too many times.
Posted on Jul 08, 2008
My Eee PC notebook's special function keys and touch pad are not working
Have you tried a System Restore to a date before this issue? Have you done ANY updates?
Apr 13, 2013 | ASUS Eee PC 1005PE (SeaShell) Netbook
Small red light on the top left corner of the touch pad is not working. how can i fix it?
Depending on the make/model of the computer, there is sometimes an "on/off" button for the touchpad either at the edge of the pad, or in the function keys.
Is the pad actually working?
Jan 13, 2011 | HP Computers & Internet
Scroll bar in my touch pad is not working
Go to control panel then mouse properties and see if it needs to be reconfigured. Sometimes they just change on their own if you are using a mouse as well as the touch pad, remove the mouse (device), then reinstall the Synaptics touch pad software and try setting it up. You may have to turn on that function in touchpad control settings.You can reinstall the touchpad driver, be sure though that it's for your laptop's model.
Dec 10, 2010 | Dell Vostro 1015 Laptop
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
The ''stop/clear'' and ''clock'' setting feature quit working. Everything else is fine.
This is either a defective touch pad membrane or the entire main control board is not functioning correctly. many times, the unit will have a separate touch control but, most newer models will have the touch pad integrated together with the main assembly. In this case, replace the main touch control assembly.
Jun 09, 2009 | Emerson Microwave Ovens
Touch Pad issues JT952-30
Hi richard..
the ribbon connector that connects the touch pad to the control may not be correctly connected. you may try to remove and reconnect it... be sure to have the power to it turned off..if the is not the solution the replace the touch pad...
Aug 16, 2008 | GE Profile JT952 Electric Double Oven
Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
May 21, 2008 | Kenmore Dryers
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
 Grubhead
Grubhead
