Question about Midland 40-Channel CB Radio CB Radio
I have a midland 98 plus cb, every time i swich it on it comes on to channel 9 , i would like it to be on 33 how can i save it so wenever i swich it on its on chanel 33
Hi i have a midland 98 got very low volume from internal speaker even with dial on max. would it work just by fitting an external speaker?...
Posted on Mar 12, 2011
    Problem Solver:
  • 44 Answers
There are a switch on front panel turn it off
Posted on Jan 03, 2011
How do you turn up the power on a midland 1001z
You can't "turn it up". You may be able to carefully compress or spread the coil windings near the Final Output Transistor (Q 14 a 2SC 2078) to get a bit more out of it but it isn't a real "Big Time" CB like the Cobra 29's. Sorry.
Feb 13, 2014 | Midland 1001Z 40-Channels Base CB Radio
Midland 75-822 schematic needed
There is...I found one in german, same radio but under the name of Alan-42. Easily translated using google. I was using a lobrary computer and was unable to print or save it, but it's ouut there.
Nov 21, 2012 | Midland 75-822 40-Channels Handheld CB...
Midland 98 low /no audio until mic is depressed, but no signal bar
there is definatly a problem here. Could be a crack in the PCB ,a cold solder joint , a loose wire , antenna SWR to high to much voltage going into the radio from the power amp. Take it to a tech to find out whats wrong,he can fix it faster then I can tell you how to concidering I don't have the set in front of me.
Jun 09, 2012 | Midland 40-Channel CB Radio CB Radio
Midland 1001z cb wont come on
check fuses and reverse polarity diode and also turn radio to on position ,SQuelch turned all the way to left and RF gain all the way to right.
Jun 08, 2012 | Midland 75-822 40-Channels Handheld CB...
Hi i have a midland 38 plus cb but the recieve is poor i have an excelent swr is there anything i can do to turn the receive up inside?
there is but if u get it wrong then you are stuft. i would just try the earth first cause altho the swr is good if the grounding is poor this will effect sigal.depending on mounting will depend on earth solution
May 01, 2011 | Midland 40-Channel CB Radio CB Radio
Hi i have a midland 98 plus,i have been told that when i talk it have very low volume and people have to turn their set up to full volume to hear me. but the same mic on a different set works fine
Look at Radio Mods or Defcom mods. To clip modulation diode inside radio. Take to Cb shop to Peak&Tune. It may be wound to high in carrier but not audio. Buy you a "Power Mic" at Radio Shack or WWW.COPPERELECTRONICS.COM.
Apr 01, 2011 | Midland 40-Channel CB Radio CB Radio
How do i retune my miland 98 plus cb
Hi peter,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
Just the average Joe cannot re-tune a radio. It has to be
done by a Tech, with the proper equipment and Tools to
line it up and get it on frequency. You can get this done at any
cb shop for about $35.00. If you just want to repair a faulty part,
you can do this part yourself and save a little money. I hope this
solution was very helpful to you.
Thanks for choosing FixYa.
John
Jan 30, 2011 | Midland 40-Channel CB Radio CB Radio
Hi i have a midland alan 78 plus multi and it will not receive or transmit ,when you press the ppt button there's no signal strength showing on the display , the power supply is good and worked fine last...
hello there your problem is simple the final transistors have blown as you have no audio an audio transistor is also required best leave it to the pros to repair goodluck
Dec 17, 2010 | Midland 40-Channel CB Radio CB Radio
When driving over rough ground my midland alan 48 plus multi cb will sometmes change channel on its own i wondered if this could be a mike problem as you can change channel from the mike
Check for loose buttons, could be something loose inside, if its changing on its own when its moving around could be from vibration that something has come loose.
When parked just try shaking the mic first if that doesnt do it shake the cb itself and see if the problem persists
May 18, 2010 | Midland Radio Communications
Midland 40-Channel CB Radio CB Radio Logo
214 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
