Question about Kitchen Ranges
We have a mouse nest in our Inglis stove insulation. We need to replace the insulation (stained with mouse **** and ****) but have been told it's not possible to get a new one?
  • 525 Answers
The insulation can be replaced, but it may not be cost effective, and you may encounter technician resistance due to the circumstances. Depending on the age of the range you may want to just replace it. Also this item usually is a special order item. I will provide you with a link to assist you in making your decision.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 08, 2008
Replace insulation in stove
Fixya is unable to suggest sources.
Nov 27, 2017 | Danby 20 Inch Electric Range
Inglis royal 100 dryer
Front and real door felts needs to be replaced
Oct 06, 2017 | Dryers
What's your problemI have an inglis royal 100 model 1a 86600 The white clothes come out with brown stains on them. It is old but seems to work well. Could it be the front gasket around the drum? I
there either is a rust mark on the tub or under the agitator oil could be leaking out or metal is rotting where the tranny shaft comes up under the agitator but like you said it's old and parts are starting to rust out and decay
Oct 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whenever I use the oven, the top of my stove gets very hot. More than it normally does. My stove is an inglis, about ten years old.
That happens with age,unfortunately.You can replace the insulation in the oven.It is not very difficult,but takes some time.
Here is a link to their site,you will find the parts you nee there.Or at a local dealer.
May 12, 2011 | Ovens
I have a small, 4-burner gas stove; no wondow in the oven door. I think my stove had a mouse infestation. I think the insulation above the oven has mouse urine in it; I can smell it, although there is no...
It is common for mice to get into the oven box insulation and nest. I had this problem before and its not likely you'll be able to get rid of the odor without replacing the insulation. Another issue is any fecal matter the mice leave behind. This can become a health hazard (expecially in an appliance that you use to prepare food). I would recommend replacing the insulation. If the model oven is correct, the insulation can be purchased for around $20 at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number will depend upon your COMPLETE model number (located on a nameplate around the oven door opening, or lower drawer opening (if equipped). On some models, the model number will appear on the back of the operator console. The first three sites on the list include exploded view parts illustrations to assist you with locating and properly indentifying any parts you may need. The insulation for the Magic Chef 31000 series is listed under the "Body" parts list.
To replace the insulation on MOST ranges, all you should have to do is lift the range top to access the oven box. The top on most ranges can be lifted by removing a series of screws that are usually holding it secure under the bottom of the front edge. You will need to open the oven door to see them. CAUTION: Do not lean on the oven door as this may cause damage to the door hinges and springs.
On the Magic Chef 31000 series, it appears that you will need to remove the burner control knobs, followed by screws holding the burner control control panel in place. You should also remove all the orifice covers and burner grates from the top of the range. Once the burner control is removed, remove the top panel, followed by the burner box top panel. The insulation will be wrapped around the oven box. It should just lift out. Depending on the potential infestation, you may want to wear a dust mask and use a vaccum to **** up any loose debris. CAUTION: Turn off the gas supply BEFORE attempting any repairs - if this is a gas range.
If you have questions, please post back and let me know. I hope this helps you.
Apr 28, 2011 | Magic Chef 31000 Gas Kitchen Range
My Inglis stove appears to have no insulation between the inner and outer panels of the oven door. Consequently the stove becomes very hot when in use and is dangerous if small children are present. Is...
I am looking at an Inglis range, approximately $479.00 and am wondering if the insulation in the oven door is less than a more expensive stove would have.
Oct 22, 2009 | Ovens
I believe there is a mouse nest in the insulation of my whirlpool ceramic stove top, how do I remove the stove top to clean it out?
Open the oven door and locate the screws under the bottom of the front edge of the cook top. Remove the screws and the cook top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
If there is evidence of any rodent infestation, make sure you do a thorough inspection of all internal wiring. Mice love to chew on wire insulation. Any bare wires can result in appliance failure, electric shock, or become a fire hazard. Make sure you do not use the range until repairs are made if there are signs of any wire damage.
NOTE: Ensure you also check the wiring inside the operator console. Remove the back panel to access.
If you have questions, please let me know. I hope this helps you.
Aug 01, 2009 | Whirlpool Accubake RF362LXTS Electric...
Gas cooker insulation
just buy some fire proof insulation from any hardware store
Jul 23, 2009 | Tappan TGF320 Gas Kitchen Range
Rat Nest in oven insulation
No the insulation must be replaced . the insulation makes the oven cycle on and off less frequently and also keeps the exposed metal surfaces cooler.
Dec 19, 2008 | Tappan TGF320 Gas Kitchen Range
Hot poinbt gas stove , mouse inside,
We had this happen recently. The smell of urine got to be too much. My wife wouldn't even go into the kitchen. I took the stove apart. the insulation under the range, which is where he was living, was soaked in urine and **** .I removed all the insulation. Spoke to a repair man. Replaced insulation with pink house fiberglas insuation and gave it a good cleaning. Smeel is gone. Repairman said this happens all the time and is a an easy but labor-intensive job. Call someone to do it if you aren't comfortable taking your stove apart.
Oct 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
