Question about Toys
Bought a K B Classics build & load track set and when I thought I was putting the battery in the toy motor, it fell apart. Apparently the battery change does not require screws like all other toys. Anyway there are several gears in the thing and I can't figure out how they go back together. Please Help. It took about an hour to get the decals on and put the track together then this happened. Very frustrating.
2 Suggested Answers
SOURCE: Bought a KB classics build
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Posted on Jan 02, 2011
I need instructions for putting the train and track together
hi Joyce.
is this a electric train set or a battery set?
could you please give me more info on this please.
can you please tell me what train set this is.
or go to this link might help you out on how to put a train set together.
how to put train track together Google Search
Dec 01, 2017 | The Toys
Opened the wrong compartment to change the battery and the gears fell out. I need a picture of gears to get it back together.
This is Bertie the bus. It stopped working so I took it apart. The Philips head (criss-cross) screw gives access to the battery. You're not supposed to take out the screws with triangular socket heads. If you do everything falls apart and you need an engineering degree to know how to put things right.
This battery holder is clear plastic, instead of black, so I can see what is happening after assembly. The red wire broke off the motor while I was looking at it so I had to resolder it. The red plate on the upper part swivels, it has an arm that holds the clutch plates together when the switch is on. The long white arm at the upper end of the gear assembly should fit into the slot of the red swivelling plate. I think it is supposed to be a noise-maker.
Bertie is supposed to go on the road, not the track and there is a plunger that cuts out the power when it is on a wooden track. This stopped working so I jumpered it to be always on.
Good luck.
Aug 25, 2011 | Seth Thomas Thomas & Friends Percy Train...
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
Jan 01, 2011 | Toys
I was given a thomas train and track set, but did not come with battery or charger. I need to know which ones to buy.
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
Apr 07, 2010 | Learning Curve Toys Thomas the Tank Engine...
Where do I put the battery for the HIT motorized Thomas train
i will try my best to help, i had the same problem with my sons as well..i was in the same situation:).You have to take the top of the train and the bottom of the train apart, seperate the top & bottom,then the battery compartment is inbetween the two..sounds confusing i know..they are very hard to pry apart.Hoped I helped!
Jul 06, 2009 | Hit Thomas and Friends Trackmaster...
Power window
It is probably just off of the track. It could be worse. take the door apart and put the window back in the guide (track). Hope this helps.
Aug 31, 2008 | 2000 Dodge Durango
My ps2 's tray just continues to spit out the loading tray!!!
You have to take it partially apart again. Remove the Cd tray. Look at the bottom of the tray and you will see a narrow track that runs the length and turns an L. The white piece that is between the laser drive and the cd tray motor has a white tit sticking up. When you put the tray back on, be sure the tit tracks into the track on the bottom of the CD tray.
Nov 27, 2007 | Sony PlayStation 2 (PS2) Console
Toys Logo
106 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
