Question about Garden
Have craftsman 4 inch motorized belt and disk sander. Drive belt seems to be burned out (slipping and smoking.) How do you remove over to drive belt? how do you replace drive belt? what size is replacement belt?
  • dsperfect Jan 01, 2011
    please confirm the model # of the sander. The newest model is 21514 but this model has a drive shaft, not a belt drive.
2 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: I have a Skil 4
18 inch is the biggest I seen however I couln't find your model number. Here is a site tell you evertthing You need to know.
http://www.ereplacementparts.com/
Posted on Oct 06, 2010
Eureka maxima vacuum smokes and smells like rubber burning..whats wrong with it..the brush turns but seems like its blowing outwards too
when you get a burning rubber smell, the drive belt is usually slipping on the motor due to friction on the brushes. Remove the belt and free all the tangled hair to allow the brushes to rotate very easily and then put a new belt on.
Jun 03, 2015 | Eureka Vacuums
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I have a 3x21 inch craftsman belt sander. It's about 12 years old. With the sand paper belt is mounted and tightened and I start to sand something the belt will slip and not sand. I checked the tightening...
The drive and guide rollers are probably drying out and won't grab the paper. Take the drive roller of and treat it with a rubber restoring compund. The roller should not come off easily.
Jul 29, 2010 | Garden
I have an old craftsman belt sander that needs oil because the engine has started smoking. I bought the right oil, but can't figure out where to put it in. Help?
Many belt sanders have sealed bearings that are packed with grease at the factory. They require no further lubrication. Sleeve bearings should be lubricated with 30 weight oil or an equivalent after each 10 hours of use.
Only about 2 to 3 drops of oil should be applied to each sleeve bearing. Avoid using too much oil. It can get on the work piece or on the belt and the belt will slip.
Apr 13, 2010 | Craftsman 0.5 amp 3D Sander
Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Oct 04, 2009 | Tools & Hardware - Others
The drive belt on my 42 inch yardman tractor is
Once a belt has slipped to the point of "smoking" it is time to replace it. It will have a worn spot on it that will cause a vibration throughout your entire tractor when you are driving in addition to being weak at the burned point
Sep 16, 2009 | Garden
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Jan 08, 2009 | Tools & Hardware - Others
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
