How many inches is 36 mm - Computers & Internet
  • 1,381 Answers
The answer is :
36 mm = 1.4173228346472
Regards .
Posted on Jan 03, 2011
I have a drolet wood stove model # db03081 i need to know how many inches from the wall it has to be, i can't make out the diagram?
It is recommended that you have it 36 inches from an unprotected wall, if the wall is protected you can go down to 18".
Dec 31, 2016 | Home
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Bellhousing bolts
Which one? Lower rear side? It requires a 36 inch long, 1/2 inch drive extension and an 18 mm socket with a good sized breaker bar, it's REALLY tight. You get it from the passenger side wheel well
Mar 16, 2014 | 2003 Oldsmobile Alero
Avalanche minimum rotor thickness
Rear Brakes JC5/JH5 Utility Only
Rotor Discard Thickness* .............................. 28.50 mm (1.122 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 29.0 mm (1.142 inch)
Rotor Thickness-new .................................... 30.0 mm (1.181 inch)
Rotor Maximum Allowable Lateral Runout ................. 0.05 mm (0.002 inch)
Rotor Maximum Allowable Scoring ........................ 1.50 mm (0.059 inch)
Rotor Maximum Allowable Thickness Variation ........... 0.025 mm (0.001 inch)
Rear Brakes JH6
Rotor Discard Thickness * ............................. 27.50 mm (1.082 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 28.0 mm (1.102 inch)
Rotor Thickness-new .................................... 29.0 mm (1.141 inch)
Nov 12, 2013 | 2002 Chevrolet Avalanche
What is the Minimum Curve Radius for Model Trains?
The length of your equipment, even more than the scale of the model, is the most important factor in setting a minimum radius. The list below includes conventionally accepted minimums for each of the major scales.
  • Z Scale: 195 mm
  • N Scale: 9 3/4 inches
  • HO Scale: 15-22 inches
  • HOn3 Scale: 15 inches (narrow gauge)
  • S Scale: 20 - 30 inches
  • O Scale ("Toy"): 13.5 inches
  • O Scale ("Scale"): 72 inches
  • On3 Scale: 36 inches
  • G Scale: 24-44 inches
Jan 10, 2013 | Crafts & Hobbies
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
Dimensions for xerox workcenter pro 416 pi or si
Actual Machine Dimensions:
Width: 530 mm / 21 inches
Depth: 577 mm / 23 inches
Height: 1039 mm / 41 inches
Recommended clearances: (for ventilation, ease of use, access to features)
Front: 915 mm / 36 inches
Right Side: 700 mm / 28 inches
Rear: 200 mm / 8 inches
Left Side: 315 mm / 12.5 inches
Weight: About 50 Kgs / 110 lbs
Weight fully loaded: About 92 Kgs / 203 lbs
Dec 24, 2009 | Xerox WorkCentre Pro 416SI All-In-One...
My hp lazer jet 1600 is making big black horozonal
Measure your marks and replace whatever is indicated by this chart.
Nov 09, 2009 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
