Question about Dell 1110 Laser Printer
How to reset fuse of toner cartridge - Dell 1110 Laser Printer
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I PUT A NEW TONER AND IT IS SAYING THERE IS EMPTY
Are you sure it was a full NEW toner cartridge?? Not an old one you had lying around.
If it was a new one the next question line goes as follows.... the machine will say in the display to "Rplace toner soon"...that dosn't mean its empty and to replace it..that means itsLOW and you should have a new toner cartridge "on-hand" because it will soon stop printing and say "REPLACE TONER". At that time the toner cartridge should be replaced, when it is installed a "fuse" on the cartridge blows and resets the toner light on the display. If you installed the toner cartridge when the display was saying "replace toner soon" you have blown the fuse in the new cartridge, now the machine has run about another 100 copies and says "replace toner"....but you now can't reset the light because the fuse is already blown because you may have replaced the cartridge too early!!! WHAT CAN YOU DO if that is the case...you can replace the fuse on the cartridge..its pretty easy to see, just replace it with another mini-fuse of the same rating written on the existing fuse..then put the cartridge in again..the fuse will blow, reset the light and away you will go. When all else fails read the operators manual.
Jan 23, 2011 | Muratec MFX-1430 Copier
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Why toner empty error in samsung sf 565p
I have an SF-555P and have installed numerous cartridges. The last one was a Samsung brand and it didn't have the little fuse taped on the top. I never knew what this was fur until I had problems. When I first installed the new cartridge the "Toner Low" display remained lit. I shook the cartridge and it persisted but it printed well. Then about 100 pages later I got the "TONER EMPTY" and the printer stopped. After researching the issue I found that the fuse is actually a reset for the printer counter and when the new cartridge was installed without the fuse, it never reset.
You will need a 5X20 Fast acting fuse, no greater than 315 ma. You can buy a 4 pack from Radio Shack for about $3 (P N 2701046). Install it with a piece of electrical tape in the slot on the toner cartridge and make sure the contacts are exposed. The printer will blow the fuse and reset the counter. Don't use a bigger fuse, a slow-blow or anything that won't burn open quickly or you will be buying a new printer.
Mar 18, 2010 | Samsung SF-565P All-In-One Laser Printer
I refilled my sf 565 pr machine, but after refilling it is still showing me low toner
First time
I am not clear what was toner refill your printer.
Other brand I mean hp/canon.It is not supported toner for samsung.Try first time clean drum.If it not fix may be change toner cartridge.
Mar 04, 2010 | Samsung SF-565PR/XST Printer
Replaced toner alarm light is still on saying replace toner
The toner has a fuse in it. When you replace the toner the fuse blows and resets the toner counter/light. Sometimes it blows and fails to reset. If you can solider you can replace the fuse and try again. Otherwise you will have to exchange the toner cartridge for a new one.
Jul 03, 2009 | Muratec F-300 Fax
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
My xerox PE16 mistakenly thinks there is no toner, even with a new toner cartridge. 1. How can I tell it that the sensor should be reset? AND/ OR 2. How can I print faxes from memory (they refuse to print...
What has most likely happened is the fuse either fell out of the new cartridge or is not making good contact. Look on the top of the cartridge, there is a sliver and glass fuse that is supposed to be on the cartridge to reset the toner counter.
Be sure that fuse is there. If it isn't the cartridge will not reset.
If thats the case you can replace the fuse with a good one or contact whoever you purchased the cartridge form for a replacement.
Jan 14, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Dell 1110 Laser Printer Logo
103 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
