Question about KitchenAid Dishwashers
The clean light keeps blinking and the dishwasher will not start. I pushed the cancel button and it runs for about 30 seconds and just shuts off. Nothing happens when you push the start button.
  • 4,323 Answers
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Posted on Jan 01, 2011
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
DISHWASHER LOCK
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
Aug 15, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
188 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
