Question about GE Dishwashers
Even after a deep cleaning cycle I keep getting food particles on the inside of the glasses that sit in the top rack of the dishwasher. The unit is only 5 months old! Help!
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Posted on Jan 01, 2011
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
    The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
    Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
    Dishwasher Residue and Film on Dishes
    heatman101
    Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
    Small food particles getting stuck
    Check your drain filter and clean them. refer user manual for location
    Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
    Food remnants left on top rack of glasses and ceramic mugs.
    Before loading into the machine clean the particles that are sticking to the dishes.
    Check the drain filter at the bottom rack and clean. It is user cleanable
    Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
    Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
    Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
    Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
    Jan 24, 2010 | Maytag Dishwashers
    Whirlpool du1055xtsq 3 not cleaning top rack of
    In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
    Nov 25, 2009 | Whirlpool Dishwashers
    Top rack of dishwasher seems to deposit particles of food on to glasses so not only are they dirty at the end of the cycle, the pieces of food particles are difficult to scrub off them. This happens with...
    check the holes on the sprayer for the upper rack, somtimes they get pluged up and the top rack dishes wont get sprayed off. if they are pluged remove them and wash in a sink
    Oct 26, 2009 | Dishwashers
    Kenmore 665 15899 dishwasher won't clean
    Make sure the filter inside the dishwasher is cleaned out and read about my advice for dishwashers for more tips.
    <a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
    Jan 31, 2009 | Kenmore 15899 Built-in Dishwasher
    Dishwashers Logo
    109 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Garth Jackson
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
