Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
E44w46lcd is hd ready. No hdmi port. I use a digital hi def cable box. can I hook up a blu-ray player?
    Master:
  • 362 Answers
Yes just use the red green and blue plugs
Posted on Jan 01, 2011
My Vizio blu Ray player displays a pink screen. What to do? I am using an Hdmi cable and Time Warner HD box.
You hook up your Blue Ray player to your TV using the HDMI cable, not to your cable box.
Jan 12, 2015 | Vizio Televison & Video
How do I hook-up a blue ray HDMI to my AKAI HDTV thru a digital cable box?
If your TV doesn't have an HDMI port on it then you'll not be able to use the player. Some players have hi def output jacks, but it isn't true HDMI so using a hi def cable would defeat the blu ray players resolution when viewing a blu ray disk.
Nov 17, 2014 | Televison & Video
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Trouble hooking up sony components..Bravia, Home theatre, blu-ray
Got your post, I will work with the model #s. Get back with you soon. Also a tip for now: HDMI carries true digital video and audio so you may not need the optic cables.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 30, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
