Question about Broan-NuTone Allure QS130SS Kitchen Hood
Fan blows air down instead of pulling up - Broan-NuTone Allure QS130SS Kitchen Hood
Sounds like the motor is wired backwards. You'd probably want to get an electrician in to take the motor out and rewire it.
Posted on Jan 22, 2011
2 Suggested Answers
  • 744 Answers
SOURCE: I just had a Broan Elite E662 hood installed and
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Posted on Dec 18, 2009
Why would new fan motor blow the air backwards
WIRES ARE CROSSED OR REVERSED, OR PLUGGED IN WRONG. SWITCH THEM, SEE IF THAT WORKS, DO U UNDERSTAND ?
Apr 29, 2014 | Alpine Air XL-15 Air Purifier
Allen & Roth Eastview ceiling fan. How do I reverse to pull up warm air instead of blowing air down?
Look for a slide switch on the side of the housing beneath the motor. If the manufacturer wired it correctly, the up position will pull up warm air and the down position will blow air down.
Jan 09, 2014 | Dryers
Condensor fan spinning in reverse
THE MOTOR IS A 3 PHASE MOTOR JUST SWITCH ANY TWO WIRES TO THE MOTOR AND THE MOTOR WILL RUN THE OTHER DIRECTION. BE SURE TO DISCONECT THE POWER TO THE UNIT BEFORE DOING THIS.
May 17, 2013 | Intertherm P3RA-048K Air Conditioner
Fan spinning backwards
If its the original mtr. or was working fine before then mtr is bad replace mtr with new capacitor
Fan on outside unit spins counter clockwise pulling air in instead of forcefully blowing air out as it should. This fan doesnot look reversible, could this be the wrong fan or is there a way to reverse it?...
air should be coming out of the top. It will work either way. If your fan is reversible it will have a sticker on the side explaining how to reverse it and it will have exttra wires plugged into each other right at the motor. good luck
Jul 28, 2010 | Goodman CLQ36AR49 Air Conditioner
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been too impressed with the efficiency of the fan. Today I noticed that it seems to blow out instead of sucking...
Hoods should blow out from the chimney, its defianately not a wiring problem. If it is blowing down towards your cooker instead of sucking up then you should contact Range as it could be a manufacturing fault.
Dec 06, 2009 | Kobe RA3836SQ Under Cabinet Range Hood
I need to replace my condenser fan motor. I replaced it once before but instead of blowing out the top, it was blowing on the condenser. Should it blow out of the top? If so, what direction should the...
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
May 08, 2009 | Heating & Cooling
96 cadillac radiator fans
No the radiator fans do not have anything to do with the A/C, they help keep the motor cool in traffic. It sounds like you might have done some damage to the wiring with the jury rig repair job.
Apr 20, 2009 | 1995 Cadillac Seville
Broan-NuTone Allure QS130SS Kitchen Hood Logo
383 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
