Question about Hasbro Beyblade Master Dranzer Special Ed. Hyperblades
Looking for diagram of the inside of the launcher. Zip cord was inserted with the teeth the wrong direction. We took the launcher apartto get the zip cord removed and the 3 inside pieces came out before we could see how they fit inside. Just need to put it back the way it was and put the 3 screws back in. Thanks!
How can download google play store in my nokia x2 fastlene
Easy Steps to Install Google Play Store on Nokia X Devices:
1. Root Your Nokia X Smartphone. 2. Download & Install Any File Manager with Root Access Enabled. (For instance Root Browser) 3. Download & Extract NokiaX_Gapps_KashaMalaga_28.02.2014.zip into system/apps using Root Browser. 4. Reboot your device. (Turn it off and then turn it on again.) - After successful reboot, you will be able to see Google Play Store installed on your Nokia X Device. Now you can install your favorite apps from Google Play Store. 5. If you need to have Google Now Launcher Experience on your Nokia X Device. You will have to manually install all .apk files present in this archive after extracting it: NokiaX_SomeGoogleApps.zip
and have google now launcher
Aug 15, 2015 | Nokia Cell Phones
Need to replace power cord for bissell model 6585
A BISSELL Authorized Service Center should be able to help you out. You can find one nearest to you and call them first if you want:
http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&cid=ccsocial
Mar 31, 2012 | Bissell Vacuums
Water on floor after dehumidifier runs for about one half hour either directly drained to sump pump hole or bucket.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers, though.
Hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Dehumidifiers
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
I have a Acer 5536 Laptop and am looking for Information of Details of the Keyboard what key does what
Click HERE it's a direct download from Acer's site (975kb in size). it's a PDF document inside a zip file your os judging by your computer age should open the zip file as if it was a folder. then you need Adobe Reader (Or Foxit reader which is A TON smaller but just as good) you want to start at about page 4.
the link that it directs you to above is also included below for those who would rather copy and paste
http://global-download.acer.com/GDFiles/Document/QuickStartGuide/QuickStartGuide_Acer_1.0_.zip?acerid=633743378817820724&Step1=Notebook&Step2=Aspire&Step3=Aspire%205536&OS=V10&LC=en&SC=PA_7
Oct 28, 2009 | Computers & Internet
I removed a feed-through Leviton rotary switch from a fan cord so I could remove the grille. I didn't see how it was wired. How do I get it back on properly?
These types of switches use what's called an IDC (Insulation Displacement Connector) which consist of a set of sharp edges teeth, that look somewhat like a 2 bladed fork, staggered inside the hard plastic switch body.
Make sure you unplug the fan before attempting any repair!
When you join the two (2) halves of the connector, and screw together the switch body over the lamp cord, those forks/teeth will pierce the insulation and go around the two internal copper conductors inside the zip cord and make an electrical connection.
You should try to get the connector placed very close to where it was before, as the cord has been compromised by having this type of connector installed on it and as such, really should have the entire cord replaced from a safety standpoint IF you can't get it back on the proper location.
You should be able to see where the connector was by simply looking at the wire cord and by matching up each side of the switch body with the indents left on the lamp cord. (there are only two possible ways it can go).
Push in on and tighten the screw and you should be fine. Try it after you're done and if you have any issues (sparks, not working easily or correctly), just get some new lamp cord and rewire the fan and put on a new rotary switch, as they're only about $1.50 +/- brand new.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Electrical Supplies
I am trying to download a free trial copy of M.S office 2007
This is not my work. I simply complied the work of others for your convenience.
DOWNLOAD LINK:  http://thepiratebay.org/torrent/3805420/Microsoft_Office_2007_With_Genuine_registry_entity_enabler or Direct download: http://torrents.thepiratebay.org/3805420/Microsoft_Office_2007_With_Genuine_registry_entity_enabler.3805420.TPB.torrent
Note, this Second Edition DOES NOT make any changes to Office 2007 (see below).  This is a full version of Microsoft Office 2007 (US English Only) packed into a CD image (.uif) containing:  * Microsoft Office  Enterprise 2007 -  Access 2007 -  Excel 2007 -  Groove 2007 -  InfoPath 2007 -  OneNote 2007 -  Outlook 2007 -  PowerPoint 2007 -  Publisher 2007 -  Word 2007 ^  Microsoft Office Visio Professional 2007 ^  Microsoft Office Project 2007 ^  Microsoft Expression Web (new FrontPage) *  The "Make Office Genuine" Registry Entities only works for Office Enterprise. ^ You will not be able to do Genuine Updates from Office Update if Viso, Project, or Frontpage are installed. The serials are written in by the launcher application, if there are problems they're also in the readme file inside the CD image. All the products don't need activation, therefore you do not need a keygen, this is not a trial, it lasts forever. Windows Update does work with this Microsoft Office 2007, but if you want to do "Genuine Office Updates," you need to use the Registry Pack for Office 2007 to make Office truly genuine. SYSTEM REQUIREMENTS: Windows XP SP2 or later (Vista compatible) (64-bit compatible with limitations) Processor: 500Mhz RAM: 256MB Disk Space: ~2GB Install Notes: Please burn file with MagicISO or Mount as a CD with MagiDisk For support with Microsoft Office 2007 visit http://office.microsoft.com/ Second Edition: *Launcher updated v1.2 - Increased chances of serials being inserted by launcher - Version number in launcher *Launcher.ahk changed to Launcher.txt for easier opening. *Registration Entities added -Allows you to make your copy of Office 2007 Enterprise genuine, so you can do official Office updates from Windows/Office Update. -Please read the Informational Readme file under MAKE OFFICE GENUINE for more info. NOTE: This is a compilation of the registry pack and the torrent Microsoft_Office_2007_Complete_Version. This is not my work. I simply complied the work of others for your convenience.
Jul 12, 2009 | Computers & Internet
I have a 7hp briggs and straton craftsman self propelled push mower. It's a few years old but runs great, the only thing wrong is the self propelled part won't engage. I took it apart down to the axle but...
Could be a stretched out/broken belt, a worn out transmission or the drive teeth on the inside of the wheels could be worn out. I would start by looking at that. Remove the drive wheels and check for damaged or missing teeth.
Apr 20, 2009 | Craftsman Garden
Putting inside back together
I found the company website. There is a section on parts. In this section it gave you a schematic diagram of the inside. Very easy to put back together with a picture!!!
Dec 05, 2008 | Frigidaire 18 in. FDR252RB Built-in...
Replacing power cord
I replace one on my U6439-900. I took the back cover off and had to cut the wires and put new wire nuts on. Then I secured them really well with electricians tape. Might help to even put on a zip tie around the wiring. Hope that helps.
Jul 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hasbro Beyblade Master Dranzer Special Ed. Hyperblades Logo
142 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
