Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What does the code Lf mean - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 4,323 Answers
Hi
LF means Long Fill. It means that the washer is taking a longer time to fill; it may be due to low water pressure, due to faulty pressure switch or due to faulty water inlet valve. Please try and clean the inlet filter screen. If this doesn't resolve your issue then check the connections at Water inlet valve. Make sure the connections at the fill valve are firm and check the continuity using multimeter. To access the fill valve take the two screws in the back that are connected. Now, pull the back of the cover towards you and lift it off. Check the three multicolored wires connected to the inlet housing that you have to remove. Next remove the two screws on the inlet housing. Now, pull the housing from the detergent cabinet then back towards it to remove the entire inlet unit. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
  • Tkc38 Jul 20, 2011
    Very helpful. Thank u Daniel.
  • Daniel Scott
    Daniel Scott Jul 20, 2011
    You're welcome
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: what does the code LF mean?
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
  • 6 Answers
SOURCE: Lf what does it mean?
LF = Long Fill
Is water supply connection turned on.
Are hose screens plugged? ( these are inside the inlet on the machine where the hoses connect )
Is water entering the tub? If so, check the pressure hose connection to the machine/motor control. This is the main control unit. There is a service manual inside the machine. If you open the top of the unit with a screw driver in the front, the manual should be on the inside of the front panel.
Posted on Dec 15, 2007
On my Maytag washer, what does the LF code mean?
LF means Long Fill. Here is a video showing you how to fix that code: https://www.youtube.com/watch?v=1M-XgRT3obc I hope that helps! :)
May 10, 2015 | Maytag Washing Machines
What does the error code "lF" mean
Do you mean "LF" if so that's a "long Fill" code. usually means the machine is taking to long to fill. Check your water supply line. Make sure the faucets are fully open, no kinks in the hose's or sediment in any inline filters etc.
Feb 15, 2015 | Whirlpool Duet GHW9150P Front Load Washer
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
What does LF mean - my kemore washer quit working
hello
mean while LF error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
The LF error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the LF error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Kenmore 24032\24036 Top Load Washer
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
The washer is showing a code of LF what does this mean
LF Long Fill
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
212 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
