Question about Toys
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are several gears that fell out but I can't figure out how they go back together. Please help. Took me an hour to put decals on the thing and put the track and parts together then this happened. Very frustrating!
I have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Posted on Jan 02, 2011
Opened the wrong compartment to change the battery and the gears fell out. I need a picture of gears to get it back together.
This is Bertie the bus. It stopped working so I took it apart. The Philips head (criss-cross) screw gives access to the battery. You're not supposed to take out the screws with triangular socket heads. If you do everything falls apart and you need an engineering degree to know how to put things right.
This battery holder is clear plastic, instead of black, so I can see what is happening after assembly. The red wire broke off the motor while I was looking at it so I had to resolder it. The red plate on the upper part swivels, it has an arm that holds the clutch plates together when the switch is on. The long white arm at the upper end of the gear assembly should fit into the slot of the red swivelling plate. I think it is supposed to be a noise-maker.
Bertie is supposed to go on the road, not the track and there is a plunger that cuts out the power when it is on a wooden track. This stopped working so I jumpered it to be always on.
Good luck.
Aug 25, 2011 | Seth Thomas Thomas & Friends Percy Train...
My front driver window fell off the track or the clips fell apart. I got the interior panel off have realigned the glass...... Now what, is there a diagram of the window and track so that I could just put...
you should have adjustments along the bottom of the tracks, what you need to do, is get the window inside those glides, and squeeze the slides into the edges of the glass window, that should keep it in line and on track here watch this, it might give you a better idea, this is pretty much the same as with Most door glass http://www.youtube.com/watch?v=Uu3SiUyWo-8
Jul 19, 2011 | 2001 Lincoln LS
Left click is not working
Unscrew the mouse and check for the contact and adjust the alignment of the casing to the click switch contact. Reinstall the HP wireless mouse software that might reset the settings. Have a nice day.
Feb 18, 2011 | HP Wireless Optical Mouse
Battery on my Ipod classic completely died and now wont work
The first thing to try is an ipod reset. Here are the instructions from apple on how to do this: http://support.apple.com/kb/HT1320
If the battery is truly dead, they are pretty easy to replace. Same with the hard drive. Batteries go for about $8 including shipping on ebay, and in most cases come with instructions on replacing. One word of caution, when you pry the 2 halves of your ipod apart, there is a small ribbon cable on the top side. Try not to damage that :D
Jan 02, 2010 | Apple iPod classic MP3 Player
Deleting loaded tracks ie ones I've loaded
You should try taking the battery out. if you unscrew the for screws on the back there will be a battery just take that out and put it back in this should delete everything if it doesnt then i dont know. dont worry about takeing it apart your only takeing the back off to where the battery is. just like your cell phone.
Jul 13, 2008 | SanDisk Sansa e250 MP3 Player
My ps2 's tray just continues to spit out the loading tray!!!
You have to take it partially apart again. Remove the Cd tray. Look at the bottom of the tray and you will see a narrow track that runs the length and turns an L. The white piece that is between the laser drive and the cd tray motor has a white tit sticking up. When you put the tray back on, be sure the tit tracks into the track on the bottom of the CD tray.
Nov 27, 2007 | Sony PlayStation 2 (PS2) Console
Toys Logo
526 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
