Question about KitchenAid Dishwashers
Kitchenaid dishwasher....clean light will not turn off. Dishwasher will not turn on. Just had motor and pump replaced on Thursday 12-30.
  • 4,323 Answers
Hi
If clean light is blinking indicates an issue with heater circuit, door switch or wash pump. To resolve this please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Posted on Jan 01, 2011
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
Pump clamp failure fixed and now dishwasher clean light blinks 4 times and controls are locked
I would start by calling that Technician back out. If it is a common problem with your model, did the technician inform you of that when he was there last? Did he even mention the POSSIBILITY that the pump might have water in it and may need to be replaced?
If not, I'd want to know why not. This sounds like something he should have been aware of and checked for, especially if he was a Kitchen Aid appliance service technician. That's the way a "handyman" might do something, but not a certified repairman.
Nov 28, 2013 | KitchenAid KUDE70FXSS Builtin Dishwasher
I have a Frigidaire 1000, 1200 series. I noticed the dishwasher motor sounding louder lately while it was running. The other night I turned it on to run. Later I noticed that the three lights on the...
Check for obstructions inside in the bottom first and or the pump might be clogged. If it's not some type of obstruction or clog it is likely your motor has died or is almost dead. Start planning on replacing your dishwasher. I suggest to go with a higher end brand. Kitchenaid Superba EQ, Electrolux Wave-Touch, Bosch 800 Series for example.
Sep 10, 2013 | Frigidaire Dishwashers
Kitchenaid diswasher replaced control panel and dishwasher is not working again
Check the door switch, it could be a loose wire or broken door latch switch.
Feb 29, 2012 | KitchenAid KUDS01DJ - Multiple Color...
TOP SPIN ARM NOT SPINNING TO CLEAN TOP RACK OF MY KITCHEN AID DISHWASHER. IT IS ONLY 1 1/2 YEARS OLD AND MY TOP TACK IS SUDDENLY NOT CLEANING
Hi.
First ensure that the arm is not getting stuck, and check that the orifices are free.
When the top arm is not spinning you may need to replace pump and motor assembly. First it is good looking for blockage in pump hose.
If the appliance is less than two year old, then it may be covered by limited warranty. Call Kitchenaid at the number listed in the owners manual to verify your warranty status.
Regards.
Nov 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
The dishwasher is making a "buzzing" type of noise. I've taken out everything and it's still doing it--seems to be coming from the motor.
You'll need to clean and possibly replace the chopper and/or impeller.To get to the chopper you need to remove all parts you can from the pump assembly inside the dishwasher.
To get to the impeller you'll need to pull the dishwasher out and remove the motor.
Finally, there is still chance that the noise is from the motor itself. Good luck!
Oct 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid Dishwasher KUDK01ILBS1
Yes, you are at the point that where the wash motor needs to be replaced. There is no magic bullet to avoid doing the replacement.
If you want further guidance, please post back here. Ok?
Apr 11, 2009 | KitchenAid KUDK01TK - Multiple Color...
Loud Squeal: Clean and Rinse Cycles
Just on a whim i would say the bearings in the motor are worn.Any leaks?It's also possible that some broken glass went through the screen and into the pump motor if any glass has been broken.
Apr 09, 2009 | Dishwashers
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Sep 01, 2008 | KitchenAid KUDMO1FK - Multiple Color...
Dishwashers Logo
402 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
