Question about Kenmore HE2 Plus Front Load Washer
My front load kenmore he2plus is showing a f-24 code what does this mean model#11047532600
  • 4,323 Answers
Hi
Error F-24 means water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is caused by a failed temperature sensor. It can also be caused due to a wiring failure or a failed electronic control board could also cause this fault code. Unplug the washer & remove the kick panel in the front. Use a multimeter to check the resistance of the temperature sensor. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. It should read around 10K ohms (10,000 ohms) of resistance at room temperature. If the reading is less than 7500 ohms then you would need to replace the sensor. If the resistance reading of the temperature sensor is fine, then the issue is with wiring failure or a bad control board. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
I have a F-01 fault code on my Kenmore HE2plus front load washer. model # 11047512601. Sears talked me thru the software resets and still had the F-01 error. do I need to replace the Main Control Unit?
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Thank you !!
Jun 28, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore He2plus washer that gives me an error of F33
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore (HE2PLUS) front-loading washer leaking out the front door,,,,,,,,C. Pellecer
check the inner door seal it may be damaged that may be why it is leaking
What is code f21 on kenmore he2plus washer and how do i fix it
It means you have a drain problem. It could be a pressure switch or the drain filter plugged.
Jul 14, 2009 | Kenmore HE2 Plus Front Load Washer
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
F 01 code won't come off, washer won't start
you have to buy a new ccu unit in sears if you dont have warranty the cost is betwen 175 to 200 $$
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer he2plus
My HE2 Plus vibrates terrible. Moves all over the place. Anyone else with this problem
Jan 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
264 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
