Question about Whirlpool WED5100VQ Electric Dryer
The dryer comes on but only blowing cold air. where is the heating element located so i can replace. or is thee a breaker somewere in the dryer
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
WHIRLPOOL DRYER WONT HEAT
1st thing is to reset the house breaker for the dryer, it is a 220 volt breaker, the dryer only needs 110 volts to run but needs 220 to heat, so the breaker can be partially tripped which will only allow for it to run but not heat. If that is good make sure where the cord attaches to dryer terminal block isn't burnt up, you can lose 220 there as well. If you have 220 to the dryer then you either have a bad element or thermal cutout located on the element with the hi limit thermostat, those parts can be tested for continuity out of operating condition
Jan 31, 2014 | Whirlpool Dryers
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
Dryer wont heat blows cold air
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Roper Dryers
My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
Dec 28, 2009 | Washing Machines
My dryer is blowing cold air and not drying at all
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 03, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer is blowing cold air
most likely the igniter. cost under $50
Aug 01, 2009 | Dryers
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
My dryer is just blowing cold air
Check the breaker box make and make sure the breaker is all the way over to the on side and then if it still continues check the thermal fuse and the heating element.
Apr 01, 2009 | Whirlpool LER4634J Electric Dryer
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
Whirlpool WED5100VQ Electric Dryer Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
