Question about Singer 4830
Show how to thread the bobbin singer 4624 - Singer 4830
  • 27 Answers
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
Posted on Jan 10, 2009
Michaelle
  • 65 Answers
SOURCE: Singer 4624
http://www.everysource.net/search.aspx?qrt5=sewing%20machine%20manuals
Posted on Jan 24, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
SOURCE: threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Posted on Feb 14, 2010
How do I fix bobbin case for a singer 4624?
I don't know what happened to it that you feel it needs to be replaced, but bobbin cases are available for all models, and they're usually relatively inexpensive. Many sewers, as a matter of fact, routinely have one or two spare cases on hand. I just looked it up, and there's one for sale on EBay for $9.50, including shipping. http://www.ebay.com/itm/BOBBIN-CASE-Singer-3103-3105-3130-3140-3314-3317-3343-360-4325-4624-4814-4817-/271264360513?pt=LH_DefaultDomain_0&hash=item3f289da841.
Oct 15, 2014 | Singer Sewing Machines
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
How to thread bobbin in singer 6412 model
singer has a free pdf manual to download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 6412) & click search
Jul 11, 2012 | Singer Sewing Machines
Bobbin threading for Singer 2001
singer has some free manuals
Go to the home page
In the box put the model number (example 117) & click search
or try youtube
May 15, 2012 | Singer 6423 Sewing Machine
Bobbin thread too loose in singer 9805c
change the needle
make sure the thread isn't coming off the thread take up lever
clean under the needle plate & bobbin area for lint or loose threads
try a different thread
make sure the fabric & needle & thread are compatable
do you have a manual?
Go to the home page
In the box put the model number (example 9805 ) don't a the C in the box
& click search--if you don't find what you need--contact singer customer service
Mar 19, 2012 | Singer Sewing Machines
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
I have a singer Futura CE-250. I am having problems with the tension I think. While embroidering the top thread is showing completely on the underside of the material. In other words the bobbin thread...
One of the things they don't really tell you about embroidering with the singer machines is that you really do need to use the same color in both the bobbin and the top. No matter how much you adjust the tension, you will still end up with some of the thread from both showing through on the other side, unlike with most other machines.
I found this out from a Singer technician about 3 years ago when I had the same problem with my CE 150 and was going nuts! He worked with both Singers, Vikings and Huskvarna's. and saved my sanity after demonstrating a lot of technical stuff that basically showed me why Singers did this.
Save your sanity-just bite the bullet and use the same thread in the bobbin as you do in the top.
May 27, 2011 | Singer CE-100 Futura Computerized Sewing...
The bobbin thread shows
I am having the same problem and can't seem to find the answer. Please email me if you have found a solution!
Debr535@yahoo.com
Sep 30, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer 4624
Jan 23, 2009 | Sewing Machines
Singer 4830 Logo
175 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
