Question about Kenmore 98702 Stacked Washer/Dryer
On spin cycle the tub begins to shake violently even with an empty tub.
  • 5 more comments
  • c_palombi Jan 01, 2011
    need help in removing front panel. can,t locate any screws whatsever. suggestions???
    can't find means of removing front panel no visible screws anyfurther suggestions..
    thanks for your help . can't locate any screws ref your schematic. i have a different model than referenced.. my model is 110.92962100. any suggestion???
    this is a 2001 model. the basket is centered . agitator turns freely also when move front to rear and side to side agitator and basket move as one in all directions as if on a gimbal.??
    don't know if you received the previous however the unit was purchased in 2001. when lift the lid the agitator is centered and it does rotate freely. can move agitator and baskets in all direction front to back and left to right. its as if they're on a gimbal when moving about all axis. any suggestions??? thanks. still don;t know how to access the insides.....
  • c_palombi Jan 02, 2011
    hi had it for one day will check under the agitator in the a.m. thanks.
    back with you, have removed agitator and no signs if wear or breakage. evidentally the probs. are beneath the basket. how do i access this area and do you have any suggestions as to what the problem is.. it appears to me as tho something is broken or came loose in the mechanism that keep the basket in place right now you can swivel eniter basket and agitator in a circular motion. any suggestions would be appreciated
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
The first place I would check is the main support which holds the tub in place. Remove the front panel, there should be two screws.
Then examine and inspect closely the frame assembly below the tub which supports the entire assembly, right where it sits on the base and is supported by a "snubber", check for cracks or separated welds.,
i.e.
( part # 131373610 available at "repairclinic.com" or searspartsdirect.com" to name a couple for about $200USD )
This is an upside down view of the support, but you should check for breaks in the locations I pointed with the arrows.
This is a very common occurrence with these models unfortunately. If all appears O.K., then continue checking for springs unfastened, oil on the base, or the snubber itself completely worn.
There's a possibility of a worn bearing etc. but you should see signs of leaking under the tub if that is the case.
Let me know what you find and I'll see if I can help you move forward from there. Good luck.
Regards,
Macmarkus :)
Posted on Jan 01, 2011
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Jan 01, 2011
    Hello again,
    The front panel is held in place by two screws along the bottom, (if indeed the model number is correct...kenmore 98702) as shown in this illustration.
    The screws will be either a square( robertson) or a star( philips ) and once removed if you pull the panel down towards the floor an inch or so it will pull off.
    Let me know how you make out.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    To your post " i have a different model than referenced " That actually changes everything we discussed and makes it irrelevant to this point, this is made by whirlpool, the one you posted is made by frigidaire.
    Let's start over then. The front doesn't come off nor does it need to with this model.
    How old is your washer ?
    When you open the lid does the basket look centered, does it move around freely if you grab the agitator and move it back and forth...front to back, side to side ?
    I'll watch for your reply.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    I did receive your reply, however I'm currently out and therefore only have my iphone as a means to send & receive posts. That being said the model of washer you have is very involved to gain access to the basket & support/suspension assembly. I'm not sure on your mechanical skills, but I would recommend calling a pro if you need to service it internally. ( which is likely )
    The one other item I'd mention you can check relatively easy is the drive block under the agitator. If you remove the agitator you'll see where the basket is fastened to the drive...check it for signs of wear or breakage.
    Let me know what you find.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jan 02, 2011
    No problem, I will try and help if you need any just let me know. The agitator is held in by a single bolt under the center cap.
    Regards,
    Macmarkus :)
Spin vibrations
Make sure the legs on all four corners are down tight and even level the machine with this 4 pads. If the machine is level it will vibrate less, and then not all machines are completely quiet when working, especially on spin cycle..
Jan 22, 2014 | Kenmore Washing Machines
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore he2 washer shakes violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Kenmore washing machine shakes violently
There is the tub that spins on the bearing the " the active tub"(the one the clothes go in obviously) and around that tub is the "stationary tub", between the two are what they call "snubs" these are either rubber wheels, bushings or on cheaper models just a rubber boot that works as a shock absorber if you will, and keeps the movement of the the "active tub" with in its axis. If a wheel is broken, or a bushing/boot is torn or broken then there lies your problem.
I hope this helps.
Aug 06, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
49 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
