Question about Kenmore 600 7962 Dryer
Dryer wont turn on. light is on when door is open. When you push on button you can hear a faint buzzing noise where timer is.
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Electric clothes dryer wont turn on but I hear a faint buzzing sound
Hello:
the noise could be coming from the timer which will be going through the motions if the door switch is not working right( door open -no drying)
Jul 08, 2017 | Dryers
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Whirlpool dryer will not start
open top panel should flip up two screws at lent trap screen if on top of unit when top panel is up push start button then push drum while you hear that buzzing noise if drum starts it needs a new motor
Feb 21, 2009 | Kenmore 63942 Dryer
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Kenmore 600 7962 Dryer Logo
117 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
