Question about Kenmore Dryers
I have an old Kenmore front load dryer. It has been great. The door opens downward and is supported by a wire lead, one on each side of the door. Both wire supports to the door have broken. How do I repair these wire supports that hold the door when it is open. It appears I need to take the front panel off and it appears I have to take the dryer apart to do so?? Serial number is M81029349 and the model number is 76876100 thank you so much for you assistance.
jsrock516
  • 5911 Answers
SOURCE: How to take apart a dryer?
First of all, UNPLUG the dryer if you plan on servicing the inside. There are still dangerous voltages present with the dryer turned off.
Lift the front of the dryer slightly in order to place a block of wood under the front feet (I recommend a couple of small pieces of 2 x 4). This will give you access to the screws without having to hold the machine up at the same time. There should be a couple of torx style screws under the bottom seam of the panel. Remove these screws and the panel should drop down and come off. Sometimes these panels can stick. If this occurs, tap on the side slightly and it shoudl come free. I hope this helps you. If you have any further questions, please post back with your comments.
Posted on Feb 07, 2008
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
huuum
  • 750 Answers
SOURCE: Dryer won't stay on.
tc7059d4.jpg9729365.jpg3403fe5.jpgThe wiring diagram for your dryer is shown in the first image below. A thermal fuse is normally in the circuit to the igniter on many gas dryers. I recommend checking this fuse. On dryer model 11073032102, you can access this fuse by _unplugging the dryer, shutting off the gas supply,_ and removing the bottom front service panel as shown in the second image below. On some Kenmore dryers, you have to remove the back panel to access the thermal fuse. The thermal fuse is located on the blower housing . The third image shows the location and replacement procedure. To test the thermal fuse, remove at least one wire (with the dryer still unplugged) and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms (continuity). If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.NOTE: If the thermal fuse is blown, check the venting for your dryer. Restricted exhaust venting can cause the thermal fuse to blow.
thank You Huuum
Please remember to leave a solved rating before you sign off!
Posted on Jan 23, 2009
SOURCE: Kenmore 417.81042000 Electric dryer has loud squealing sound
My dryer of the same model number had the same issue. The teflon/plastic wear points are worn out or have fallen off. They are about $22.00 plus shipping at the site below. Disconnect the power, lift (with force) the top off at the front of the dryer and you will have access to remove and replace.
Felt glide assembly - Upper felt seal with three glides attached. Comes with adhesive.
Part Number: AP2150497 made by FRIGIDAIRE
www.appliancepartspros.com/modelsearch_model.aspx?part_id=2150497&&model_id=301211
Posted on Aug 30, 2009
canbruce75
  • 1776 Answers
SOURCE: how to remove top panel of kenmore dryer model
Check the video at the following link and see if you find the information helpful in changing the door switch. Sure hope it does and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Oct 01, 2009
How to switch door side on dryer
Not that simple like it is on a modern refrigerator. The electrical wiring is set up for a door safety switch. That switch can probably work either door swing. The door would need to be reversed and holes cut in the dryer for the latch. The old latch would need to sealed up. It is uncertain that the metal on both sides is capable of supporting the door hinge. In any case it seems like a difficult and doomed task.
Jan 03, 2014 | Maytag Centennial White Gas Front Load...
How to install dryer rack in kenmore HE3 dryer
Open your Kenmore HE3 dryer door. Look for the ledge on the inside rear of the dryer wall.
Insert the rear wire leg of the dryer rack into the drum, resting the wire leg on top of the ledge. The front frame should rest over the dryer lint screen.
Push down on the top of the front frame of the dryer rack to secure it over the dryer lint screen frame. Close the dryer door once you load your items on the rack.
Feb 02, 2013 | Kenmore Dryers
My Kenmore Elite 7.0 HE4 dryer has been great, but
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dryer won't turn
It sounds like the belt is stretched or slipping. The belt needs to be replaced. It has been a few years, but dryer cabinets haven't changed that much.First, unplug the dryer from the electical outlet. If the lint filter slides out the top, then remove the two screws that you see in that top door. Pop the two front clips and open the top like a clamshell. You should be able to see where the belt goes around the drum. The front is held on by a couple of bolts at the top of each side. If you remove them the front will swing out, but be careful with the door switch wires. Before removing the old belt, pay attention how it goes around the motor tension pulleys. Slide the old belt off and slide the new one on. Reassemble. I hope this helps
Mar 28, 2010 | Kenmore Dryers
I need to replace a door switch on a Kenmore Dryer
I'm not too familiar with the model but you either have screws that are just above the door (open the door first) or two metal tabs in the front that hold the top on the dryer. The two metal tabs can be seen if you take a flashlight and look where the top meets the front about 8" from each side roughly. A flatblade screwdriver inserted at the top of these fasteners will release them from the top. Next have a 5/16 nut driver to remove the two screws on each side holding the front onto the sides. There may be screws at the bottom as well. You may not have to remove the front at all. Also HAVE THE POWER DISCONNECTED! Don't want ya to get fried. Remove the leads from the door switch on the right and remove.
Oct 29, 2009 | Kenmore Dryers
Opened dryer door mid-cycle left open 1 hr. Dryer won't restart
there is a door switch on left upper corner of drier opening, make sure the little prong is clicking when you push it in. this turns the drier back on when the door is closed and the start button is pushed.
Dec 31, 2008 | Kenmore 63942 Dryer
Reversing the Door
nope only the dryer doors are reversable..last washer to have reverable door that i know of was old neptune
Sep 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 seies belt replacement
you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Apr 05, 2008 | Kenmore 65924 Electric Dryer
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Reverse Door
You can't reverse the washer door, only the dryer door.
They don't make the washers reversible because the door latch and wiring harness would have to be relocated to the other side. It just isn't practical from a manufacturing standpoint.
Sorry, Mike
Nov 04, 2007 | Kenmore 43142 Front Load Washer
Dryers Logo
93 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
