Question about Bryant Heating & Cooling
How to connect a thermostat to a bryant 80+ furance.
    Genius:
  • 1,033 Answers
First thing is to turn off the switch on the side of the furnace, next remove the old thermostat and the wires from it. On the new thermostat you should have y, c,w,g,r therminals. The yellow wire goes to the Y terminal, the white wire goes to the W terminal, the red wire goes to the R terminal, the green wire goes to the G terminal and the C is comonly not used.
Posted on Jan 01, 2011
Screen on Bryant thermostat is blank---Batteries?
Heidi, all thermostats that I am familiar with require AAA, AA or nine volt batteries and are accessed usually be separating the thermostat from the sub-base. Some older stats have a 'ribbon' connector that maintains connection during removal, but most of the newer stats have 'pin' connectors. A picture would help...could you post one with a smart phone ??
Apr 19, 2015 | Heating & Cooling
My goodman furance runs on full cycle then it won't start again til i turn power off then back on
May be a stuck relay on the circuit board. The only other thing I can think of would be a thermostat having intermittent problems.
Feb 28, 2015 | Goodman Manufacturing Goodman GMS81005CN...
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
AC IS TURNING ON BY IT SELF AFTER I SWITICH IT OFF, HOW TO SOLVE THIS PROBLEM
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
Winchester 80% gas furance blows the 3 amp fuser
this is a low voltage, there is a short in you wires somewhere, if I was a guessing man I would say thermostat.
Oct 29, 2010 | Goodman GMS90703BXA Heater
Furnace
could be bad control out of the box it does happen recheck you have the motor terminals correct is the motor getting voltage?
Jun 19, 2009 | Bryant 463AAC008BA Air Conditioner
Heating & Cooling Logo
166 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
